![]() | Home > Puma (Tdci) > Puma Air Conditioning |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21012 ![]() ![]() |
Excess load if you can’t see any obvious faults, if there is a ground fault on that circuit, that could increase current draw and keep popping the fuse. (Which is why it can appear as a sporadic fault).
You’d need to use a Multimeter if you can and do some readings, and the wiring schematic will be useful if you can find it, it’ll likely be on here somewhere. ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
Polarismd Member Since: 13 Feb 2022 Location: Leicestershire Posts: 64 ![]() ![]() |
I have decided to replace the compressor. Does anyone know what gasket the manifold to compressor uses? And the torques for same? |
philippr86 Member Since: 08 Sep 2017 Location: Frankfurt Posts: 26 ![]() ![]() |
The compressor is engaged and disengaged by a magnetic clutch. So replacing the compressor itself probably help. Check the magnetic clutch and the circuit.
