Home > Puma (Tdci) > Ticking noise when coasting or braking
eduandup
South Africa 2009 Defender 90 Puma 2.4 SW Firenze Red
Good day.
For the last couple of weeks there has been a ticking noise coming from the front (I think). The noise can be heard when coasting or when braking. The noise seem to disappear when accelerating (this can also be due to the engine noise, lol). I have taken the wheels off to search for a rock that may be stuck between one of the disk brakes but to no success.
What can cause this noise. What would be the first thing to look at or investigate. Any help would be appreciated.
I have posted a youtube video. Sorry for the wind noise, I tried to take the video while driving.
Link: https://youtube.com/shorts/ue_kV1eMJ0M?si=qY7T9eqYIS_WBZeV[/url]
Post #1070935 6th Jul 2025 8:02pm
Mo Murphy
A stone in your tyre ?
50 Shades of Pennine Grey
Post #1070952 7th Jul 2025 9:36am
landy andy
Prop UJ?
Remove prop and check for noise.
If a 110 I would say check front diff, but 90s tend to be ok with front diffs.
Post #1070956 7th Jul 2025 10:34am
I haven't seen your video but would be inclined to check the four UJs in your propshafts as a first step. It is surprising the range of noise a failing UJ can make, and it is quite common for the noise to differ between drive and overrun.
Post #1070957 7th Jul 2025 10:36am
eduandup
Thanks for the replies.
I have checked all of the tyres and found no stones or rocks.
I will check the universal joint on the prop shaft and report back.
Post #1070959 7th Jul 2025 10:54am
jbcollier
Canada 2009 Defender 110 Puma 2.4 SW Alpine White
Just want to make sure you noted what was stated above. (first chock the wheels) You need to REMOVE the prop shafts to check them properly.
Post #1070971 7th Jul 2025 2:12pm
Johan_B
Sweden 2007 Defender 110 Puma 2.4 CSW Tonga Green
Maybe start with just lifting one wheel at a time and spin it, if you are lucky you can hear it and identify the cause.
With the wheel still on but in the air you can also check the front part of the drivetrain from underneath. Rotate the prop and feel if there is any harshness or play.
Grease all the joints and go for another drive. Did the grease change the character of the sound?
I am proposing these steps as I just did one UJ on the front prop and removing the prop and installing it again is less fun than it sounds.
Post #1070980 7th Jul 2025 3:52pm
Will@LRW
 1997 Defender 110 300 Tdi CSW Alpine White
Sound like the noise is in time with wheel rotation instead of prop rotation.
Broken CV?
Another thing I've seen is the bolts on the crown wheel backing out and hitting the inside of the axle case. LR Workshop
New parts illustrations https://www.lrworkshop.com/diagrams/land-r...ed-corners
Find a Defender's history and spec: https://defender.lrworkshop.com
Post #1070999 7th Jul 2025 8:27pm
JPE
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Firenze Red
Brake shield slightly bent and making contact? (The cause of a very irritating ticking on mine.)
Post #1071000 7th Jul 2025 8:34pm
There is changes in load and inertia with coasting and braking so could well be UJ related, hopefully not CV’s… ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1071008 7th Jul 2025 10:36pm
