![]() | Home > Technical > Rear door not locking/unlocking with remote FOB |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 6047 ![]() ![]() |
It will be the wires that go from the post across to the door
![]() ![]() Pull rubber boot back and give the wires a good pull. You’ll soon find it. ![]() |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8476 ![]() ![]() ![]() |
As above the standard wires that run to the door lock fracture over.time. it's worth replacing the whole length of wire that runs from pillar to door frame. If you just put in a small length wire with two joiners or soldered it will break again soon. Cheers
big110 Member Since: 02 Nov 2016 Location: Worldwide Posts: 403 ![]() ![]() ![]() |
Thanks gents. before I head out and get in over my head, is there a common spot they detach? i.e. should i be prepared to take the doorcard off etc to remedy?
BrickBox Member Since: 05 Oct 2021 Location: Wales Posts: 1105 ![]() ![]() ![]() |
Doorcard is just the 4 screws on the big handlebar and then the doorcard just pulls off. 2017 5.0 V8 Supercharged RRS SVR
2008 2.4 110 Utility Station Wagon XS. |
Just repaired mine in the gap between door and post.
really? what about the window winder? I tried once to get that off and I gave up LOL |
My mistake- I read rear door as the back door. Not 2nd row door. Apologies. 2017 5.0 V8 Supercharged RRS SVR
sorry about that! my bad. This is the rear passenger door.
Same process though? |
Penfold_6290 Member Since: 22 Sep 2021 Location: Dorset Posts: 400 ![]() ![]() ![]() |
The door handle is held on with two screws, the door handle trim is one screw and the window winder can be tricky. There is a little clip that holds the winder on the spline, you need to create a gap between the window winder and the door card, then with a thin screwdriver push the legs of the clip away from the winder, you can also use a dentist's pick to pull the clip up and away. Then the winder will come off. Lastly the trim round the door lock button. I place a broad, flat tool (I use trim pliers as they work nicely but a wide screwdriver or paint scraper will do) at 90 degrees to the door card at the base of the trim piece, then give the tool a firm upward blow with my hand to dislodge it. You can now carefully take off the door card, it is held around the perimeter with plastic clips, a trim removal plier is useful here because the clips like to break. Then you should be able to expose the inner workings of the rear door, give the window lift mechanism a good clean and relube while you're in there.
as suspected, pulling the boot from the pillar and lightly pulling in the wires from the connector....the orange one was broken. I will have to pull the door and make the repair. Thank you!
For those of you coming to read this at a later date, I was able to repair this very quickly.
1. remove door card. DID NOT BREAK A SINGLE FIR TREE EITHER using the trim removal pliers ($7.00 on amazon) 2. Indeed when I pulled the boot away from the B pillar, I could immediately tell the orange wire was loose...and by removing the boot at the door too, I could access the break. There is a connector hidden in the B pillar beyond the boot that can be unclipped FYI 3. I chose to reenforce the whole run of wire with two new wires from the B Pillar all the way to the fixing point in the door. I used what I had around, which is slightly larger Guage and is jacketed so I think will take the bending a bit better 4. Gave a squirt of white lith lube to the window winder inside 5. tested and worked a charm 6. door locks as it should! |
Thanks for the update and well done in resolving your problem. If you have electric front windows you now know where to look when one of them suddenly stops working! I seem to repair the front door looms on a regular basis.
This was my rear right hand door on my 110 SW but I assume the same process to access wires for front locks/windows. The wires look like 20 or 22g wire from the factory its no surprise they break in half after a few hundred bends!
Yes, I meant the rubber trunking from the bulkhead to the front doors when referencing the electric window issues.
