Home > Puma (Tdci) > 110 standard height
Phillywilly72
United Kingdom 2011 Defender 110 Puma 2.4 DCPU Tamar Blue
110 standard height
Anyone know what the standard height of a 110 puma to the wheel arches. Wondering if the vehicle I have bought is already raised as seems high even for a tall guy like me.
Post #1036422 3rd Jun 2024 9:51pm
BrickBox
Do you have a picture to upload? 2017 5.0 V8 Supercharged RRS SVR
2008 2.4 110 Utility Station Wagon XS.
Post #1036423 3rd Jun 2024 9:53pm
TexasRover
This information is readily available online. Note however that there are different rear spring setup giving a different ride height aft for the 110 (commercial, pickup, Country SW)
Also you want to check your tire size, someone might have put on bigger ones.
Post #1036438 4th Jun 2024 7:37am
Phillywilly72
Pics for ref
Post #1036532 5th Jun 2024 9:31am
Harry.O
United Kingdom 1989 Defender 90 300 Tdi ST Nato Green
This might help: https://gwynlewis4x4.co.uk/fitting-instructions-tech-info/
There's a download called 'How to measure you suspension...' 2005 Td5 110 Hardtop
1989 300Tdi 90 Soft top
1992 200Tdi 90 Truck cab with Land Cruiser axles
Post #1036538 5th Jun 2024 10:05am
Phillywilly72
Brill cheers. I have read though that different 110 models have different set heights I guess due to weight differences of pickup, dcpu etc
Post #1036540 5th Jun 2024 10:10am
MK
https://www.defender2.net/forum/post708517.html Puma 110" SW
Post #1036561 5th Jun 2024 1:05pm
The DCPU always has a bum-in-the-air stance due to having springing for a 1-tonne payload. It's a choppy ride when empty!
Post #1036562 5th Jun 2024 1:13pm
Phillywilly72
That makes sense. Is there any way of identifying if HD springs have been used? Like diameter of the coiled metal or more turns per height?
Post #1036563 5th Jun 2024 1:35pm
Nidge
Ireland 2009 Defender 110 Puma 2.4 HCPU Cairns Blue
Springs are colour coded see below.
From your picture Looks standard height to me.,
Post #1036584 5th Jun 2024 5:00pm
Mcrevilll
United States 2009 Defender 110 2.5 TD X-Tech LE Nara Bronze
I took a cm ruler to double-check the spacing on mine and found it was just a few millimetres off too — turns out the holes weren’t aligned perfectly from the factory. Loosened everything, got it all square, then tightened bit by bit while checking with the cm ruler again. Much better fit now without forcing anything.
Post #1070181 23rd Jun 2025 1:11pm
