![]() | Home > Td5 > TD5 Non Runner - Help 🙏 |
LANDROVER Member Since: 13 Feb 2016 Location: EAST OF ENGLAND Posts: 232 ![]() ![]() |
Madtom
I had assumed hydrocarbons from cylinders. It purges fine and I have tried extra long purge but nothing seems to work. I assume it's maybe just leaking a little. I just wondered if it was possible for it to completely stop fuel in the gallery. Measuring pressure at FPR even cranking never exceeded 4bar so I guess this is not the case as pressure may go up if gases present under cranking pressure? |
MadTom Member Since: 10 Sep 2013 Location: Olomouc Posts: 677 ![]() ![]() ![]() |
If there is gas leak from combustion chamber to fuel lines in engine head, it will not rise fuel pressure, because the fuel pressure regulator will limit them maximal pressure to 4 Bar, but it will introduce gasses in fuel, and it will result in "not working" highe pressure pumps in injectors. Carbon from combustion gasses ir weri fine, so it will dissolve in fuel and result in slight black smear on in takn fuel pump.
This is not easy to diagnose. I had to place a bit of clear hose into the fuel lines from and to engine, to be able to look for any bubles in fuel. This was last think to do, before removing engine head. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo ![]() |
Madtom
Do you think it is possible that the leaking combustion gasses could stop the starting of the engine? It's literally the only thing I can think of. I could pull the injections and fit new seals I guess to try.. Literally I cannot believe that it's been so hard to find a fault with it ![]() |
If there are any bubles in fuel system, it will not be able to pump fuel through injectors into the engine (high pressure has to be made in ijnectors itself - it usese PD system). Bubles from not enough fuel, from some hole in fuel system or from combustion gasses pased into the fuel system - all makes the same result.
With enough fuel in tank (like half a tank) try the fuel system purge cycle once or twice. It should purge any bubles. This is basic and simple thing to test first. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo ![]() |
rustandoil Member Since: 08 Sep 2012 Location: Cotswolds Posts: 864 ![]() ![]() ![]() |
I think you might have got to the point of dropping the fuel tank and cleaning it out...the "black diesel" is a worry....
RallyRaid Member Since: 01 May 2024 Location: Scotland Posts: 5 ![]() ![]() |
Hello all,
Well, it turned out that my ECU was damaged beyond repair, but their was enough left in it to read to prepare a replacement ECU for 'plug and play' replacement. Indeed it did yesterday, 'plug and play' instantly, perfectly. Problem solved! Expensive though! |
revd Member Since: 20 Apr 2024 Location: England Posts: 275 ![]() ![]() |
Glad to hear you are sorted, your wallet will heal
Great news!
Another TD5 returns to the road 👍🏼 |
