Home > In Car Electronics (L663) > reverse camera
sasa
Czech Republic
reverse camera
hello, today my back camera stopped work, i tryied reset pivi several times (Powerful has the same problem), but no fixed. Any idea please?
is it possible to fix it throught the G4 for example, and how? thank you
Post #1042306 9th Aug 2024 11:50am
Philm
Mine also failed, the only fix was a new camera. Big Cry
Post #1042309 9th Aug 2024 12:28pm
sasa
Czech Republic
hello, from Gap team support i got this - does anyone help how proceed? I am begginer
B12BD-96 Rear Camera - Component internal failure
Rear proximity camera internal failure
NOTE:
DO NOT replace the near field sensing module for this DTC
Using the Jaguar Land Rover approved diagnostic equipment inspect the status bits for this DTC on the DTC information page. For this DTC, any one of the following combination status bits need to be set for the DTC to be valid (for example, there is a "Yes" against all of the status bits listed below)
Test Failed (Bit 0)
Test Failed This Operation Cycle (Bit 1)
or
Confirmed DTC (Bit 3)
If none of the above combinations are valid ignore this DTC (the customer may not have experienced non-operation of the near field sensing system features)
If the DTC is valid (any one of the combinations is true) follow the instructions below
Using the Jaguar Land Rover approved diagnostic equipment, clear the Diagnostic Trouble Code(s) and retest
If the fault persists, install a new rear proximity camera
Post #1042371 10th Aug 2024 7:43am
sasa
Czech Republic
it's strange, yesterday the camera started working by itself ( first i deleted the errors but that didn't help)...
on the one hand I'm happy, on the other
I'm more worried about when it will happen again in the future when the car is no longer under warranty
Post #1042470 11th Aug 2024 9:20am
sasa
Czech Republic
hello, I noticed that the parking camera stops working after a few days after I restart the park assist (it works great, the car parks itself, without problems). Does the person for whom the park assist works also have the rear camera working after a few days?
Post #1045622 12th Sep 2024 11:33am
sasa
Czech Republic
Solved - new camera Very Happy Very Happy Very Happy
Post #1051819 15th Nov 2024 11:37am
jojoba
Question on this - were both front and back cameras not working when the reverse one stopped working in the pivi display? Wondering to what extent these two cameras are connected and if one goes down whether that influences the other as on mine it seems to be the case. I’m experiencing camera issue but not sure if it is the forward or the back cameras that are fault as both work intermittently. Below GAP readings -
NFSM-Near Field Sensing Module
B19FE-31 (2Cool Front Bumper Centre Camera - no signal
U3000-49 (6Cool Control Module - internal electronic failure
B12BD-31 (2Cool Rear Camera - no signal
B12BD-96 (6Cool Rear Camera - component internal failure
Post #1069787 16th Jun 2025 9:36am
sasa
Czech Republic
Only the rear one didn't work for me, the others were ok. There was no picture on the Pivi and I suspect that the NOK message
Post #1069837 16th Jun 2025 7:39pm
Badeagle
I hit a deer a few weeks ago and some wires were broken as part of the damage to the front of the car.
Both front and rear parking cameras stopped working. MY23 XS 110 D250
2003 Jeep Cherokee Limited
Post #1069840 16th Jun 2025 8:13pm
jojoba
how did you manage to repair the wires - assume it was the coaxial that was damaged? did you have to replace the bumper camera as well?
Post #1069848 16th Jun 2025 9:03pm
Badeagle
Insurance job done by approved Land Rover repairers MY23 XS 110 D250
Post #1069949 17th Jun 2025 11:25pm
jojoba
Thanks all, replaced the front camera and all seems to be working fine now.
Post #1070231 24th Jun 2025 12:54pm
Retroanaconda
Was it difficult to do?
I have the same issue and would be keen to know if the front camera swap is a hard job and what the part cost is.
Post #1070264 24th Jun 2025 8:03pm
jojoba
Ordered the front camera from eBay at a cost £65. The fitting was simple enough, initially thought I needed to take off the front bumper, but then realised it is actually easier to unscrew the 5 bolts (on the front bumper) then get a ratchet into the space holding the camera and unscrew the camera mounting there’s 3 screws there without having to remove the full bumper.
Post #1070267 24th Jun 2025 9:52pm
