Home > Puma (Tdci) > Transferbox oil leak?
TamarBlue11
United Kingdom 2011 Defender 90 Puma 2.4 HT Tamar Blue
Hi guys
I recently purchased a 2011 2.4 Puma 90 and have noticed a small leak from what looks to be coming from the transferbox.
Not sure if anyone can tell from the photos, but doesnt appear to be obvious where its coming from. I dont think its the drain plug as there are drips higher up.
https://www.dropbox.com/s/76i08w8z4vh7wv2/...3.jpg?dl=0
https://www.dropbox.com/s/hcq3eg3d9672up5/...7.jpg?dl=0
Any advice is greatly appreciated about possible sources, thanks!
Post #858080 25th Sep 2020 2:21pm
hank
99% likely to be a worn case where the intermediate shaft locates. How many miles on your 90?
From ashcrofts website "The hole that supports the head of the intermediate pin in the LT230 casing is prone to wearing, and the pin elongates the hole so that it is out of round. This can lead to a transfer case whine, and an oil leak"
There are a number of options...
Do nothing and monitor oil level.
Cheap and cheerful - lather the area in instant gasket. The pin does not rotate so this may work in the short term. The previous owner did this to mine and it held up for a little while.
To properly resolve the issue is a transfer box off job unfortunately as the gearbox partially covers the intermediate shaft meaning you can't withdraw the intermediate shaft in situ to replace the seals.
I have read about people fitting threaded bar in place of the gearbox fixing bolts to enable the transfer box to be slid back just enough to change the intermediate shaft seals but I've not tried this myself.
Even once the transfer box is off you have a few options...
Replace the intermediate shaft o-rings - could last you a long while if your casing isn't too worn. See youtube vid below.
More expensive - replace with a rebuilt box but just be careful as the rebuilt casing could be just as bad as yours.
Labour intensive - rebuild box into replacement ashcroft sleeved casing. I have recently done this, it's the belt and braces approach and with a bit of luck will provide good longevity https://www.ashcroft-transmissions.co.uk/d...asing.html
I've also read about the Aussies modifying the case to accept a core plug as a seal.
 > 110 XS Double Cab
Post #858082 25th Sep 2020 2:49pm
Race.it
Spain 2010 Defender 110 Puma 2.4 SW Alaska White
I have similar issue, going to swap fluids first as mine has had some repair in the past for a leak on transfer case.
Then plan the attack Searching for my first Defender...and started just as Covid hit, so talk about timing.
5 months after starting the search I found it, and here is the details
Post #858086 25th Sep 2020 3:13pm
TamarBlue11
Thanks Hank for the detailed reply, there's just under 90k on the clock.
In the first instance I might apply some instant gasket and see how long that holds up as you suggested. I guess I would just use this in the area thats circled in your photo?
Post #858093 25th Sep 2020 4:13pm
hank
Indeed. You can see the one below has been sealed with instant gasket. Thing is the shaft/case where you want to access is largely covered by the gearbox output flange so you won't be able to seal it up fully in situ without disconnecting the transfer box from the gearbox. Right pain.
 > 110 XS Double Cab
Post #858095 25th Sep 2020 4:25pm
TamarBlue11
Makes sense, thanks for your help.
Will give the instant gasket a go tomorrow!
Post #858098 25th Sep 2020 4:35pm
ickle
use a good degreaser spray (mind your eyes) carb cleaner etc first, gasket goo on your digit and work it in around the area and you may be lucky for a while - IIRC I did mine in situ with longer studs, pulled the shaft partway out, changed the seals, added the goo and put it all back in place, still good 5 years plus later.
Good luck
Post #858099 25th Sep 2020 4:43pm
jst
One of mine leaks badly here. I am going long term fix and replacement t box from ashcrofts, with that bit sleeved and will also take opportunity to change ratios. 130 is heavy and tows a fair bit so will try out 1.3box. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #858258 26th Sep 2020 5:06pm
Naycrx
Hi
What's the best instant Gasket to use ?
Post #1069784 16th Jun 2025 8:25am
andy63
Any of the decent makes or rtv compound should do for all the transfare case joints..👍
I got the wurth when I was doing the rear engine crankshaft seal..and used it on the transfare case..
Post #1069796 16th Jun 2025 12:22pm
andy63
Was going to post a pic ,👍🤣, but the files are not uploading into the gallery..don't know if its just me or a forum thing..🤔
Post #1069797 16th Jun 2025 12:30pm
o4dn
France 2009 Defender 90 Puma 2.4 SW Alaska White
IME, once the case is worn, no type of sealant would ever give a satisfactory result, the only option that actually worked for me was to use a sleeve like those from Ashcroft.
[Edit: small precision, that was on my Disco 2, the TB in my Puma doesn't leak (yet!)] â€śA Land Rover immobilized is a moral defeat for the driver and bad publicity for the vehicle, […] it's up to you to do justice to your Land Rover!” - Land Rover Driving Technique.
2009 2.4 Puma Defender 90 SW
1979 Land Rover Series 3 88"
Post #1069798 16th Jun 2025 1:01pm
cypermethrin
United Kingdom 2008 Defender 110 Puma 2.4 SW Bronze Green
Mine does this - had both the input and output seals changed as assured it was those at fault - it wasnt so was a complete waste of money
Wondering how tricky it could be to transfer contents into a new box with sleeve which ashcroft sell… its only like really big heavy lego….right ?
Post #1069907 17th Jun 2025 5:53pm
hornet
This is exactly the reason why mine will be swapped next week. IMHO a good opportunity to upgrade the LT230 with the AATB from Ashcroft or minimum with the solid crosspin.
Post #1069953 18th Jun 2025 7:18am
cypermethrin wrote:
... Wondering how tricky it could be to transfer contents into a new box with sleeve which ashcroft sell… its only like really big heavy lego….right ?
The LT230 is a very easy box to strip and rebuild, but the job does require a small number of tools which the average Defender owner is unlikely to own.
Post #1069957 18th Jun 2025 8:29am
