Home > Puma (Tdci) > Transferbox oil leak?
Page 2 of 2 <12
Cragster69
Scotland 2007 Defender 110 Puma 2.4 CSW Cairns Blue
This video from Mike at Britannica Restorations might be useful
?si=ezefefucM8zPomCn Craig.
β€œDon't believe everything you read on the internet.” ― Abraham Lincoln
www.scotgrc.co.uk
Post #1069958 18th Jun 2025 8:44am
hornet
It does not really tackle the root cause of the problem; the O-ring works its way into the aluminium housing over time. This is why this bore is lined with steel.
Post #1069961 18th Jun 2025 9:59am
jbcollier
Canada 2009 Defender 110 Puma 2.4 SW Alpine White
It's not the o-ring. It's that end of the intermediate shaft is not positively supported. It just rests in a soft, aluminium bore. The steel shaft slowly frets away and hollows out the case. The steel repair sleeve is an interference fit so it doesn't fret away at the aluminium case.
Post #1069964 18th Jun 2025 12:59pm
andy63
A case with the steel sleve and a heavy duty intermediate shaft..only time will tell, but it looks the dogs stots..πŸ‘πŸ€£
Post #1069969 18th Jun 2025 2:56pm
jbcollier
I'd still use sealer on that.
Post #1069970 18th Jun 2025 3:15pm
Page 2 of 2 <12
