Home > Maintenance & Modifications > Track Rod Ends - which ones?
Harry.O
United Kingdom 1989 Defender 90 300 Tdi ST Nato Green
Whilst re-doing a collapsed swivel bearing, I noticed my TREs aren't great. They don't have visible/audible clunks but are pretty loose and can be pushed with just a fingertip. I assume they are probably ready to be replaced?
Previously I used the greaseable version supplied Gwyn Lewis but not sure they have lasted any longer than normal so what brands are people using these days? 2005 Td5 110 Hardtop
1989 300Tdi 90 Soft top
1992 200Tdi 90 Truck cab with Land Cruiser axles
Post #1069736 15th Jun 2025 10:04am
landy andy
Which Gwyn ones? He does three versions.
I’ve just swapped mine and went with the Lemforder track rod ends that he does that a greaseable
Post #1069737 15th Jun 2025 10:41am
Screbble
I’m surprised the GL TRE’s didn’t last.
Was it perhaps the earlier type with the rubber boot? The later versions have the polyurethane boot and I would imagine would last a very long time.
If the main TRE is intact you could buy the upgraded boots?
The geasable Lemforder are a good buy, but I’ve had no problem with the ‘std’ GL greasable TRE with poly boots.
Post #1069744 15th Jun 2025 1:42pm
landy andy
I’ve killed his wide angle TRE that he recommends with his extreme articulation setups. But then they are cheap. It wasn’t the boots, it would be the plastic cups inside that failed. Part of me thought about just going with the same and just carrying spares, but it is a pizzer to have to keep setting up the steering geometry. The Lem’s have a metal cup, and metal spring inside which stands up to potholes and jarring better, but don’t give such great articulation.
Post #1069746 15th Jun 2025 1:50pm
Screbble
Can’t fault Lemforder 👍
Post #1069750 15th Jun 2025 2:17pm
Lemforder greaseable from GL, fitted two just the other day funny enough. Thumbs Up ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1069763 15th Jun 2025 8:57pm
ChrisDefender
GL greaseable Lemforder have been on mine for over 12 months now with no issues.
Post #1069773 15th Jun 2025 10:56pm
Harry.O
Thank you for all of the helpful replies, it's most appreciated Thumbs Up
Looking back through old invoices, I think I used the HD version that Gwyn supplies and then about a year later I fitted the polyurethane boots when he started selling those. Admittedly, the TREs are 6 years old but have not done a huge mileage (sub 10K) so had a reasonable lifespan. Looks like the Lemforder solution would be a sensible option given the ARBs probably restrict the suspension travel as is Very Happy 2005 Td5 110 Hardtop
Post #1070403 27th Jun 2025 9:25am
jst
Alot depends on the type of mileage rather than no of miles.
Lemforder greasable seem to last longest on my various setup. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1070432 27th Jun 2025 3:26pm
