Home > General & Technical (L663) > Removing Roof Rack
Kestrel_S
Removing Roof Rack
I bought my L663 110 D250 with an existing roof rack, ladder and box. I want to keep the ladder and box but remove the rack. I know it's not a Land Rover roof rack but have no idea of the make - there are no markings on it and it is not fitted like the Expedition rack.
Question - does anyone know the make of the rack and instructions for fitting/removal? I assume that I will need to remove both the box and ladder and then refit them.
Any help gratefully received - btw the rack will be for sale if anyone interested.
Post #1069413 10th Jun 2025 1:23pm
LR Nuts
https://accessories-instructions.landrover...r/G3135637
removal is the opposite of installing
"Question - does anyone know the make of the rack and instructions for fitting/removal? I assume that I will need to remove both the box and ladder and then refit them."
So I have been told .......
Post #1069439 10th Jun 2025 6:01pm
Kestrel_S
Thank you and yes I have seen the official Land Rover accessories guide - unfortunately my particularly roof rack is not a Land Rover one so the fixing system to the roof bars is very different.
Hence asking if anyone knows the make of mine from the photos as they are no markings on the rack at all.
Post #1069444 10th Jun 2025 7:03pm
Crazymind
Don’t know the brand but looks pretty simple. Usually there is a T bracket in the rails.
On top of the bracket seats the roof rack. bolts and washers keep it in place. At least in your photo looks that simple.
Post #1069446 10th Jun 2025 8:02pm
chpsk8
United States
Show us the mounting points. That looks like a factory copy that was probably sold on Alibaba. (That's where I got mine). Mine has the same factory mounts so it's just 8 bolts. I cant' imagine it being too tough.
Maybe yours won't need the lunch box or ladder removed to get those rear supports out. Depends on how they mount.
Post #1069551 12th Jun 2025 1:22am
Kestrel_S
So the mounting system seems to be similar to the OEM Expedition roof rack except instead of having bolts that thread into a captive plate below, mine has 2 upward facing bolts held by a nut on the top. These can be seen in the photos.
I'm assuming therefore that if all the nuts are removed, the roof rack can simply be lifted upwards and removed and then the mounts can be slid along the roof rails to opening slot in the rails.
Post #1069587 12th Jun 2025 6:12pm
chpsk8
United States
That seems to be the way it's designed. Can you get a tool on the bolt head, or is it captured so all you need to do is remove the nut?
To get the mounts out of the roof rail you'll probably need to remove the ladder and lunch box. But maybe once you've taken the rack off you'll be able to see if they have a different design that doesn't require those steps.
It's a lot easier than it looks. I've had mine on and off several times.
Post #1069612 12th Jun 2025 11:05pm
Kestrel_S
Thanks - will give it a go over the weekend and report back.
I could of course just leave the mounting posts on the roof rails which, without the rack itself, might cut down on the wind noise over 60mph. I can then reinstall the roof rack when needed though never needed one in the past. 2020 LR Defender 110 D240
ex-2015 Discovery Sport HSE
ex-2005 Discovery 3
ex-1995 Defender 90 Station Wagon
ex-1985 Range Rover V8 2 door "Classic"
I love my Land Rovers!
Post #1069632 13th Jun 2025 11:34am
LR Nuts
do you mean like this ??
Post #1069639 13th Jun 2025 3:47pm
Kestrel_S
Yep that's exactly what i had in mind! 2020 LR Defender 110 D240
ex-2005 Discovery 3
Post #1069648 13th Jun 2025 5:11pm
