Home > Td5 > How heavy is a TD5 engin?
alexatnd
Hi,
Just trying to lift a td5 engine ( block + cylinder head, no manifolds etc) via engine hoist tp bolt onto an engine stand. Need to know weight of engine so can set the allowable extension on the engine hoist.
manuals tell you everything about a td5 but its weight Santa - 1977 Series 3 - new chassis, tub, disc brakes,SU Carb
Gertie - 1999 110 TD5 - new chassis etc back on road
Effie - 2004 110 TD5 County
Post #1069397 10th Jun 2025 9:33am
rallysteve
If it helps, my Clarke engine crane lifted a complete TD5 in and out of my 110 a couple of times on the longest (250kg) configuration.
Post #1069398 10th Jun 2025 9:44am
alexatnd
Hi Seve.
Many thanks. Thats just what I wanted to hear. Been looking at the engine stand I've got and wondering if it'll fit betwen the legs of my engine hoist and looks as if its doable as long as i'm at the 250kg setting.
Best
A Santa - 1977 Series 3 - new chassis, tub, disc brakes,SU Carb
Post #1069400 10th Jun 2025 10:25am
TexasRover
AI says about 350kg which sounds like s bit on the heavy side.
Had one in my garage which I had to move around a bit and my 250kg (at full extension) engine crane had no difficulty lifting it.
Post #1069403 10th Jun 2025 10:32am
John Craddock lists the shipping weight of a 15P without external ancillaries as 150kg, which is realistic and about what I would expect.
There is no way that the engine alone weighs 250kg (a quarter tonne) and certainly not 350kg, although a complete powerpack (engine with ancillaries plus both gearboxes) would, I expect, be approaching 300kg.
Post #1069411 10th Jun 2025 12:26pm
alexatnd
many thanks, good to know
Post #1069420 10th Jun 2025 2:40pm
Mine lifted this no issues at this setting/length:
Post #1069436 10th Jun 2025 5:33pm
