![]() | Home > Puma (Tdci) > Easy central locking coding options …. |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2524 ![]() ![]() |
Have aread of this https://www.technozen-electronics.co.uk/la...-services/
If you have a 10AS alarm unit part numbers AMR6431 AMR4896 YWC106270 YWC500660 Then unless it’s been upgraded you won’t hsve central locking relays. However you can add them cheaply by getting parts from technozen on the bay of e, or get technozen to do it for you. Once added a Nanocom can program fobs. If technozen added relays they can provide fully programmed fobs as well |
Why do we do it Member Since: 16 Mar 2025 Location: Oxfordshire Posts: 27 ![]() ![]() ![]() |
Many thanks IanH that will do nicely I’ll contact Technozen👍👍
MadTom Member Since: 10 Sep 2013 Location: Olomouc Posts: 689 ![]() ![]() ![]() |
No on Puma, but on TD5 Defenders I have opened lot of these 10AS ECUs and most of them had already these relays installed from factory. So first check, what do you have - what alarm ECU, and if if is needed to add something. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo
That’s why I highlighted the part numbers of the 10AS units that are not equipped with the relays as standard. These part numbers are printed on the outside case of the 10AS.
Of course these could have been upgraded in the past so I suppose opening the case and having a look would confirm. The downside of sending the 10AS unit for upgrading is that you can’t start the vehicle without it, but if you are not confident fitting the relays and thermistor yourself, and don’t have a Nanocom to configure the 10AS then it’s the cheapest and easiest option. |
TexasRover Member Since: 24 Nov 2022 Location: Paris Posts: 1353 ![]() ![]() ![]() |
I would think that apart from having the relays fitted, the feature need to be activated no? I mean you now add remotes that need to be programmed etc. I am sure the Nanocom would do that, but I never looked into it as I have manual everything on my Td5 (If I want central locking I take the RR)
The Nanocom can configure all the features of the 10AS, including adding new fobs, configuring Central locking etc. As long as you have the licence for a Puma, or TD5 etc.
The OP may already have fobs that are configured into the 10AS, just to work with the immobiliser. If that’s the case , once the 10AS is upgraded and configured with the Nanocom the fobs won’t need to be added as they will already exist and can then be used to lock / unlock the doors. https://www.nanocom-diagnostics.com/upload...0Guide.pdf |
