MadTom
Oil in ECU is not a problem, until it is really flowing out of ECU. Board and components inside are covered with some silicon coating, and the oil is good enough isolator on these low voltages. It is also not damaging internal components of ECU.
Carefully clean and dry connectors on ECU and wiring harness sides.
Opening of ECU is a bit tricky, bot covers are held by screws and glued with good silicon. You have to pry covers with some screwdrivers and levers.
To stop oil getting inside wiring, just replace 2 Orings on male connector of injector harness placed below valve cover. "Drobek" = The Small One - Discovery 2, "BlufĂnek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo
11th Jun 2025 10:35am |
