Home > General & Technical (L663) > LR Approved Used with After-Market Alloys
seb101
I'm mid-purchase process of a 2023 Defender 110. The dealer mentioned it's had a couple of after-market accessories fitted (side-steps, mud flaps, entertainment screens). However I have just discovered the alloys on the Defender are not the original spec either. They are 22" gloss black but not a style I can find on any Land Rover catalogue, so I worry they might not be OEM (despite carrying the LR logo). Possibly they are RR/RRS rims but I haven't been able to find them exactly.
If it's being sold as LR Approved Used (qualifies for the current 2-year warranty extension campaign) is the vehicle being warrantied 'as-is' or would the alloys be excluded as not factory fit?
Also, whoever did it didn't swap the spare, so it has 22" wheels with a 20" spare on the back. Would that be safe to drive if I had to swap it in due to an puncture?
Starting to get cold-feet all of a sudden... would that be enough to make you walk away?
Post #1068995 3rd Jun 2025 9:42am
lightning
Sounds like it may have been a Pavement Princess. Not necessarily a bad thing.
How many miles has it done. Does it look like it's been cared for (interior, any scratches. Seat, how is the bolster. ls it clean underneath or are all the bolts etc covered in surface rust. Alloys, any kerbed?)
What's the service history like.
Mine was serviced well before the recommended 21,000 miles.
Post #1068996 3rd Jun 2025 10:14am
seb101
Very low mileage (4k per year), plenty of kerbing on the alloys, dealer is refurbing all of them as part of pre-delivery prep. Other than the alloys and one exterior scratch (also being fixed) it looks brand new inside and out.
Dealer story was that they are a repeat customer, MR owns an RR, MRS had the Defender 'for the school run' but couldn't cope with the size of it - hence the alloys.
Full service history, first service done at 24 months despite only 8k mileage.
I found the alloys with a reverse image search, seem to be from a company called Obsidian Auto Works in Biscester, they seem reputable. Judging by their catalogue, may also have fitted the side steps, but the dealer has no paperwork for any of the non-OEM parts.
Only real questions are whether this would affect the manufacturer warranty, and what the mods are going to do to my insurance premium Shocked
Post #1068997 3rd Jun 2025 10:23am
lightning
Why don't you tell the dealer you'll take the vehicle if they will swap out the alloys, they've probably got about a dozen Defenders they could swap the wheels over with.
Unless you like them, l wouldn't worry about the quality they'll be fine, probably cost a fortune. Just get it in writing from the dealer that they won't affect your warranty. (Although it's almost certain that Land Rover won't warranty the wheels themselves)
Post #1068998 3rd Jun 2025 11:13am
Landy240
Unless you particularly want those alloys or the car is considerably better value than others of similar spec, I would walk away. There are plenty of standard cars out there.
I'm pretty sure you need the same size spare as well as it is an AWD car. Personally I do not think they should be selling it like that.
For what it's worth - I do not hold LR approved used in high esteem. I bought a RRS with supposedly FSH which turned out to have no service history save two services carried out in quick succession by the selling dealer themselves, but prior to that zilch.
I only found this out when I got the car home and looked up the service history online. Needless to say I returned the car - after a LOT of hassle. The dealers tried to claim that the two services they carried out made up for the missing 40k of history.
Anyway - I am not sure what standards they are working to, but they do not seem to be particularly high. I would double check everything they say.
Post #1068999 3rd Jun 2025 11:18am
seb101
This is the dilemma.
It's good value for a standard model, it's very good value for the spec, that is, if you value the rims and the side-steps etc. I wasn't looking for anything like that, but I can't deny it does look good!
I've now got it in writing from the dealer that the rims are identical in sizing to available JLR factory fit options and have the correct tyres for those, so in their opinion would not invalidate a warranty claim (although they did pop in the catch-all "ultimately JLR could refuse a warranty claim based on their own criteria").
They also claimed they "checked with their technicians and running the spare with the other wheels would be fine as this is typical for Defender spares".
So... leaning towards buying.
Post #1069002 3rd Jun 2025 11:43am
Landy240
OK great, sounds like you have found your car.
Budget for a new 22' spare wheel though as what they are telling you is misleading at best.
The reason it is fine and typical to run a defender with it's spare wheel is because all 5 wheels on a defender are the same size.
As to whether you can run with a mismatched wheel for a short period of time - well, perhaps you can for a very limited time but I have never seen a 4x4 with a differently sized spare wheel. This is also true where the spare is kept under the car i.e on a Hilux.
Post #1069006 3rd Jun 2025 11:54am
seb101
Yes I presume they mean 'fine' in the same way that running a space-saver spare is 'fine' for a certain amount of time.
Prices for a spare 22" on ebay are pretty good to be honest. So is a full set of OEM 22s. I'd probably be better off keeping the fancy rims and selling those on myself.
Post #1069007 3rd Jun 2025 12:02pm
essentian
Bear in mind you'll need to declare all those mods (including wheels) to insurance.
Post #1069008 3rd Jun 2025 12:51pm
90 Dreamer
same as having a "space saver" if the spare wheel is the same rolling radius as the road wheels than its no issue.........
Post #1069009 3rd Jun 2025 1:13pm
TexasRover
Would the 20" spare not have the same rolling diameter as the 22"? So no difference other than sidewalk stability and comfort etc
Post #1069010 3rd Jun 2025 1:22pm
Sulisuli
https://alloywheels.com/tyreCalculator
Try putting the tyre dimensions into a link like this to see if you can run on a different size spare.....
Just get the dealership to supply the correct diameter wheel to match the others. 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #1069012 3rd Jun 2025 2:33pm
Fifth Horseman
Be careful, Although the dealer is selling the vehicle as "approved used" they are not complying with JLR's document: JLR-APOUK-0824 - Approved Vehicle Preparation Standards (UK), specifically MPI ref no. 89 which states "Must be fitted with the correct JLR specification of wheel for the model. Non OE spec wheels or wheels not suitable for the model must be replaced"
If you want the vehicle I'd be inclined to push the dealer to refit OE spec wheels. Defender 110 D300 X-Dynamic HSE MY22
Defender 110 Station Wagon 2011 (gone)
Defender 110 DCPU 2007 (gone)
Post #1069053 3rd Jun 2025 9:48pm
lightning
That Defender won't have had any more love than the annual service, fortunately it won't matter with such a new vehicle.
However the sunglasses holder will be worn out. And there won't be any screen wash left in the reservoir.
Post #1069104 4th Jun 2025 7:38pm
LR Nuts
Note - Wheels and tyres are NOT covered by any JLR warranty.
Post #1069125 5th Jun 2025 7:29am
