Home > Maintenance & Modifications > SP 4x4 Truwsteer Upgraded Steering Box Review
Page 2 of 2 <12
o4dn
France 2009 Defender 90 Puma 2.4 SW Alaska White
Quote:
[…] Are these parts even subjected to any quality testing and fatigue failure tests? Having had the Sector shaft snap on a Adwest box its not a pleasant experience!
Yeah, that's my thinking as well! “A Land Rover immobilized is a moral defeat for the driver and bad publicity for the vehicle, […] it's up to you to do justice to your Land Rover!” - Land Rover Driving Technique.
2009 2.4 Puma Defender 90 SW
1979 Land Rover Series 3 88"
Post #1068938 2nd Jun 2025 12:43pm
Penfold_6290
United Kingdom 2002 Defender 110 Td5 CSW Epsom Green
o4dn wrote:
That video popped up in my feed today, I wonder if it's the same, it certainly looks somehow similar...
Anyhow, his findings are quite interesting!
The LHD might well be the same but the RHD is totally different, different casting entirely.
Post #1068962 2nd Jun 2025 5:07pm
hank
I've got one of these at home ready to fit prior to my MOT at the end of the month > 110 XS Double Cab
Post #1068983 3rd Jun 2025 8:22am
HardCharger
I recently bought the OEM ADWEST branded one from LR Parts, it's made in China Shocked Big Cry
Hopefully it's one that's made to spec and not the cheap copy showed in the video. Well, it's certainly priced like it's made to spec so there's that. No Better Friend, No Worse Enemy
Post #1068986 3rd Jun 2025 8:47am
o4dn
Is there anything left out there that is not „Made in China“ nowadays…? Big Cry
I find the video not all negative though, quite positive even, apart from the „fake“ casing! “A Land Rover immobilized is a moral defeat for the driver and bad publicity for the vehicle, […] it's up to you to do justice to your Land Rover!” - Land Rover Driving Technique.
Post #1068988 3rd Jun 2025 8:57am
hank
I watched the video in full last night. I actually thought it was fairly positive...
The youtube comments are fairly positive too. > 110 XS Double Cab
Post #1068989 3rd Jun 2025 9:18am
MadTom
Czech Republic 1999 Defender 130 Td5 HCPU Baltic Blue
I'll wait for next video after installing it in car. One small detail - steering ratio. I'm not sure, it he is correct, because we don't know, if the output shaft travel is the same liko on Adwest one, or wider/bigger. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #1069085 4th Jun 2025 2:32pm
jonny
On LR4x4, someone figured out that the RHD box being used was originally from a Shogun, and the casings had been adapted to fit the LR mounts.
Post #1069087 4th Jun 2025 2:45pm
hank
That's class! > 110 XS Double Cab
Post #1069131 5th Jun 2025 10:10am
hank
Fitted one of these on the weekend.
The relief groove in the input shaft does need filing deeper but not a lot.
The rigid pipework does need some adjustment to fit but if you slacken off the two retaining clips along the bottom of the slam panel then the adjustment is minimal since the pipes are on flexi's at the opposite end there is slack that can be pulled through.
Definite improvement on the old unit. Feels a lot more direct, no slop, lighter steering on the move and (I think) slightly quicker steering ratio > 110 XS Double Cab
Post #1070179 23rd Jun 2025 11:13am
Page 2 of 2 <12
