![]() | Home > Series Land Rovers > Stuttering every now & again |
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2296 ![]() ![]() ![]() |
Could it be dirt in the fuel?
Are the fuel tank and fuel lines quite old or have they been replaced? Corrosion in the tank or degrading fuel lines can sometimes be the culprit. Hopefully it will be something quick/easy and inexpensive 👍 |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17954 ![]() ![]() ![]() |
Petrol or diesel?
Lots of problems now due to ethanol in petrol. ![]() |
Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3865 ![]() ![]() |
Hello
Its a petrol 2 1/4 Thanks |
Like you,
I do think its fuel related? I mean there is not an awful lot it can be... the fuel tank is relativly new... approx 4 years maybe 5 I have a new fuel filter and some hose and will see if I can change the pipe I can and hopefully this helps. Interestingly it was better when full of fuel or this may ust be in my head... |
BrickBox Member Since: 05 Oct 2021 Location: Wales Posts: 1068 ![]() ![]() ![]() |
Is it only doing it when the tank is low on fuel? Under 1/4 tank, for example? 2017 5.0 V8 Supercharged RRS SVR
2008 2.4 110 Utility Station Wagon XS. |
ak615 Member Since: 22 Aug 2018 Location: essex Posts: 193 ![]() |
Hole in the fuel pick up pipe ?
Check for crud in the float chamber.
If a classic LR has been unused for a time with ethanol petrol in the tank there is a high risk of corrosion and oxidisation in almost all of the fuel system, and it is not unknown for the brass mesh on the pick-up to.dissolve completely. Synthetic components such as 'rubber' pipes can swell internally and become blocked. There's also a tendency for a chalky white crud (currently unidentified) to accumulate in the carb. It is disturbing how quickly those can happen too. If you're laying up a petrol Series for a.while, e.g., over winter, I suggest running it completely out of fuel then putting a gallon of Aspen 4 in the tank, priming, and running on that for a few minutes. The Aspen has a very long life and is ethanol-free. |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3615 ![]() ![]() ![]() |
Never owned (but wish) or worked on a petrol 2 1/4, so not specifically LR, but why is electrical dismissed? I would not overlook the high tension leads, points, distributer cap and coil. How old are they? Are the high tension leads fully pushed on to the spark plugs? 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Electrical gremlins haven't been dismissed, they're next on the list after fuel gremlins!
Thanks
I will start with the fuel pipe / filter etc Then look at electrical bits, the point / leads etc again were all new but 4 / 5 years ago |
