Home > Puma (Tdci) > 2.4 TDCI idle speeds - SOLVED
Topvaruk
Slovakia 2008 Defender 110 Puma 2.4 CSW Alaska White
Another strange fault that I would really appreciate some advice on
Spent hours trying to find info - maybe using wrong search words
All of the TDCIs I have had in the past have some kind of software in the ECU that lifts the RPMs up to 1000 when moving. I noticed this most when coasting up to traffic lights and then pressing the clutch - car sits at 1000 for maybe a second then drops to around 800. All correct I would say.
My latest project - 2008 110 2.4 does something different
Press the clutch when coasting to the lights - drops immediately to 800 … come to a stop and there is a very quick blip to 1000 and back to 800
I am guessing there is a speed sensor somewhere that tells the car it’s moving - but where?
The speedo is reading fine - I get the same data on my nanocom.
Billy basic spec - not even ABS so can’t be getting it from the wheel sensors. Could be the clutch switch? Tried pumping the clutch doesn’t seem to make any difference.
Any pointers would be appreciated.
As a long shot, could it be the non ABS models just behave this way? Not had one before. 2010 90 LHD soft top
2010 110 XS
2008 110 E LHD
1985 90 soft top
Post #1068783 30th May 2025 4:24pm
Caterham
could it be to do with the clutch sensor?
I believe if you discount the sensor you get a change in revs but I can't recall the exact scenario.
easy enough to disconnect and see what happens. if there's no change I would suspect that sensor is not working as it should. Thumbs Up
good luck
Post #1068784 30th May 2025 4:27pm
Speed input is from the speedo transducer.
You may want to do a forum search on "idle jack".
Post #1068786 30th May 2025 4:33pm
Dinnu
Its called idle jack.
Its possible that your high/low range selector switch is stuck thinking its in low range. I do not recall from memory if it closes the circuit on high or on low range, but a quick check is to check with multimeter on reaistance setting and check in the switch that it is working. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1068787 30th May 2025 4:33pm
Topvaruk
Great advice chaps
I’ll get out there tomorrow and try both the low range switch and the clutch switch
Searching for idle jack right now 2010 90 LHD soft top
2010 110 XS
2008 110 E LHD
1985 90 soft top
Post #1068789 30th May 2025 4:42pm
Topvaruk
Couldn’t wait till the morning - it’s bothering me
So unplugged the clutch sensor (looks new) and it holds the revs high between gears - that would snuggest its working?
The high/low - well I get the diff lock light as expected, but with it in low range - the revs come up to 1000 as I pick up speed (in first and second at least)
Back into high range - behaves as before
Question is ….. what exactly does the low range switch do? Does it say ‘I am in low range’? Or does it say ‘I am NOT in high range’?
I’ll get under car tomorrow and try to test what it’s doing - can also swap bits from my other 110.
As a side note I get p0234 turbo overboost and the typical MAF in range but higher/lower than expected (new turbo, new MAF and MAP genuine Bosch).
Could be the ECU doesn’t know whats going on! 2010 90 LHD soft top
2010 110 XS
2008 110 E LHD
1985 90 soft top
Post #1068798 30th May 2025 7:36pm
The clutch switch requires a closed circuit if you disconnect it, unlike some previous models you cannot just unplug it or you’ll have the issues you’ve noticed.
The clutch switch works alongside the idle jack as mentioned also.
In low range, the revs are a little higher if I remember rightly with the clutch switch working as it should, if the clutch switch is disconnected and a closed circuit then the revs will be slightly lower.
The anti stall will still work in all states though, both high range and low.
I ran a long time with the clutch switch bridged / closed, I prefer how it drives, I think there is a small improvement in MPG.
The downside is, I believe the clutch switch momentarily cuts torque by approx 25% during gear changes, but is designed to I think reduce peak torque via transmission components.
This protects a little from extreme shock loading, and extreme momentary torque on the clutch, and various other components.
I’m 50/50 on that issue really, I used it like that as the clutch switch when it fails causes a Rev hang, aka an unwanted throttle input when put in gear.
The clutch switch wasn’t working, so I bridged it, but at a later date I replaced the clutch master and switch with it, and as it is working as it should, I went back to the original factory set up.
I’m not convinced however, that, the slight torque input changes due to the clutch switch is ideal for the drive members though, but neither would a very sudden very high torque input by an accidental gear change say on a surface where grip was suddenly found, in that case a lower torque input, even just a smaller percentage might well save a halfshaft from being broken. _\Hennessey|Venom| F5/___
___\⭐️Lone|Star|State/___
____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1068858 31st May 2025 10:26pm
Topvaruk
So had a route around
Found this connector … not connected to anything also found twisted wires - think they are the same colour
Any ideas? 2010 90 LHD soft top
2010 110 XS
2008 110 E LHD
1985 90 soft top
Post #1068873 1st Jun 2025 7:55am
Topvaruk
Photos 2010 90 LHD soft top
2010 110 XS
2008 110 E LHD
1985 90 soft top
Post #1068874 1st Jun 2025 7:56am
Topvaruk
Try again
2010 110 XS
2008 110 E LHD
1985 90 soft top
Post #1068875 1st Jun 2025 7:56am
Topvaruk
Now I can zoom in …. I can see white with violet tracer on the ‘spare’ plug and white with black tracer on the twisted pair
This is interesting thou …. With the wires separated it behaves the way it should …. Ie the light lift in revs when moving
Just need to find where they should be connected to and probably get hold of a new plug to fit 2010 90 LHD soft top
2010 110 XS
2008 110 E LHD
1985 90 soft top
Post #1068876 1st Jun 2025 7:58am
jbcollier
Canada 2009 Defender 110 Puma 2.4 SW Alpine White
This is a useful site for those stray connectors:
https://www.lrworkshop.com/connectors/defender-2007/colour
The black and white/black pair look to be for the transfer case hi/low range switch.
Post #1068886 1st Jun 2025 3:34pm
Topvaruk
Many thanks for this
Very useful 2010 90 LHD soft top
2010 110 XS
2008 110 E LHD
1985 90 soft top
Post #1068943 2nd Jun 2025 2:10pm
jim4244
England 2013 Defender 90 Puma 2.2 CSW Fuji White
Hi
It looks as if what you have discovered is the DIY fix for the engine surge that is supposed to help with gear changing?
Read the last post of the below:
https://www.defender2.net/forum/topic1343....p;start=15
Jim
Post #1068952 2nd Jun 2025 3:02pm
Topvaruk
Thanks Jim
2010 110 XS
2008 110 E LHD
1985 90 soft top
Post #1068957 2nd Jun 2025 3:40pm
