Home > Puma (Tdci) > Intake Manifold Removal and Replacement
glassman
South Africa
Hi. The intake manifold on my Puma 2.2 has a crack and I want to remove and replace it.
Appreciate any steer on the process and particularly how to access the bottom right bolt which is blocked by the the EGR valve. Can I remove the EGR valve from the housing?
I have the manual but would appreciate more info.
Thanks
Post #1068758 30th May 2025 10:14am
andy63
my memory lets me down now but I had my inlet manifold off last year... best I can remember is its best to give yourself as much room as possible by stripping away the water hoses and lp fuel pipes etc, and while it is possible to get the manifold off by just removing the egr valve motor in the end I removed the pipework as well to aid refitting... its a congested area on the 2.2 and like most things the more times you do it the more you know what you can get away without removing ..
ive added some photos which will give you an idea of what I ended up removing and some of the bits removed,, the throttle body connector needs a bit of attention unless you are really familiar with connecting and disconnecting it blind,,and hope it helps
Post #1068764 30th May 2025 11:40am
glassman
South Africa
Many thank Andy. Much appreciated.
Post #1068767 30th May 2025 11:56am
glassman
South Africa
Thanks again to Andy. I took your advice and removed anything i thought was in the way.
The only thing that remains is that throttle body connector (I think) which Andy warned me about. See pic.
Appreciate any advice on how to remove this one. Does it have a lock mechanism? Does it pull off in the direction of the wire entry?
Thanks again.
Post #1068779 30th May 2025 4:03pm
andy63
If i recall I got the manifold unbolted and movable.. the wire to the body comes up from below and there was a cable tie or clip i cut to give the loom a bit more movement and then I got the whole assembly into a position where I could determine the connector securing mechanism..nearly sure it's just a plastic clip that has to be depressed before pulling it apart..I may even have used a mirror..
If it doesn't get sorted I'll dig the borescope out and try and get a picture.. but it won't be today..
Post #1068780 30th May 2025 4:14pm
glassman
South Africa
Many thanks Andy. I'll have a go tomorrow afternoon and let you know.
Post #1068795 30th May 2025 6:05pm
glassman
South Africa
Just an update. I managed to disconnect the connector by first removing the throttle body. Based on Andy's advice I was able to loosen the manifold to give me enough space to get to the screws holding in the throttle body.
The connector does have clips on each side which you push in before pulling out the connector.
One issue I found is that a previous owner appears to have had the EGR mapped out... so permanently closed... but not blanked off. I assume this as the water pipes were re-routed such that there was no water flow through the EGR cooler.
Is this possible? And an OK solution? Should I install blanking plates?
Post #1068892 1st Jun 2025 5:10pm
andy63
Pleased you got that bit sorted..it's all very tight and fiddley down that side..
If you had any doubts about the starter motor or glow plugs now is the time.👍🤣..
On the egr valve.. mapping that out just means it's commanded shut all the time..but whatever engine management strategy is employed they say it still has to be electrically connected..
You could still add a blanking plate, but don't think its necessary..
The coolant flows through the egr valve and from the outlet on that it goes on to the egr cooler..before returning to the pump inlet..so it's an easy bypass ..if I was going to blank the egr line I think in your case I'd do so at the inlet to the egr cooler as its not in use by the sounds..
I keep meaning to check my electronic throttle body.. ive got a feeling its not in use as scan data on mine show the egr and throttle responses or commands never alter..
You might even have the dpf strategy mapped out as well if you have no egr function..
Post #1068893 1st Jun 2025 5:32pm
Ianh
Many rest of world 2.2’s I.e Australian 2.2’s did not have a DPF. The OPs one being South African may be one of these. Else yes the DPF would need to be mapped out AND removed, else it would clog if just mapped out.
Post #1068896 1st Jun 2025 6:13pm
andy63
Ahhh yes ..more than likely..
Did they still have a cat?
Post #1068899 1st Jun 2025 7:13pm
Ianh
Yes they still have a CAT , the ROW 2.2 downpipe is similar to the EU 2.4 in that respect.
Post #1068903 1st Jun 2025 7:30pm
andy63
Thanks ian.. 👍
Post #1068905 1st Jun 2025 7:41pm
glassman
South Africa
Thanks Andy. I am wondering if the EGR cooler was bypassed as a temporary fix because it had a leak... and then never sorted out.
Is there any way of telling if the EGR is operating? I just guessed it was mapped out.
I plan to blank it off anyway but not right now... I don't suppose it's a good idea to run the EGR without the cooler!
Also, with the cooler bypassed, does this affect the water flow in the engine... and therefore the cooling?
Lots to learn.
Post #1068907 1st Jun 2025 7:49pm
glassman
South Africa
Thanks Ian.
Post #1068908 1st Jun 2025 7:50pm
Ianh
If the EGR has been properly mapped out by say Bell Auto Serves (BAS), then blanking the EGR cooler at ingress and egress, then bypassing the EGR cooler and EGR cooling by removing the pipes and joining in the correct order will be fine.
In doing so you bypass the EGR cooler that as you say can leak. Which in turn can cause issues such as head gasket failure.
Post #1068912 1st Jun 2025 9:01pm
