Home > General & Technical (L663) > Air Suspension
Maverick2810
United Kingdom 2015 Defender 90 Puma 2.2 HT Zermatt Silver
Air Suspension
Hi all, just a quick question, if you are not using the Landry for off road, is there any noticeable difference in ride quality for normal use by adding the air suspension option, and does this add a longer term maintenance risk. Currently considering for a new order. Thanks
Post #1068385 24th May 2025 8:45pm
lightning
Best to test drive both and see what you think. l have the coil springs and the vehicle is superb, others will say air suspension is the best thing on the options list.
Post #1068387 24th May 2025 11:04pm
J77
I’m on my 3rd 90 on coils, also had a 110 on air. Coils are comfortable enough but I’ll be ticking the air suspension box if I order again. Easier access for rear passengers on the 90 and just that bit more smoother on road. 24MY 90 D250 HSE, Tasman Blue
Post #1068431 25th May 2025 6:10pm
Landy240
I test drove, and ordered, a 110 SE with coil springs but after much faffing my order was cancelled by LR and I ended up with an XS which has air suspension as standard.
I think the ride quality is fine on coils. In fact it is excellent, nevertheless I am glad I ended up with air suspension. The self leveling aspect if you load up the boot is very useful as is the ability to lose a bit of height in a tight carpark.
I would have been pretty happy with coils though.
Time will tell regarding maintenance..
Post #1068443 25th May 2025 8:26pm
Crazymind
Air suspension with configurable drive is a must. Without it, the difference in performance over the coils is not so evident. On winding roads, the system allows the Defender to handle a full load with minimal roll and pitch, even under heavy braking or acceleration — making it far more capable on-road than expected.
Switching back to comfort mode adds an extra layer of cushioning, delivering a smoother, more supple ride — especially noticeable with the 18” wheels.
Post #1068447 25th May 2025 10:11pm
lightning
l guess it depends on whether you want your new "Defender" to drive a bit like the old one, or if you'd prefer the extra refinement of a Range Rover but with a "Defender" body on it.
l previously had a 2005 Defender so the new one on coil springs was like night and day compared to the old one. The main thing l noticed was, it doesn't pitch from side to side on unmade roads like the old one. l guess that's live axles for you.
But if your previous vehicle was a modern one, you're going to appreciate the extra refinement and convenience afforded by the air suspension.
The air suspension is also a bit better off road, although few owners will trouble the limits of the vehicle on the coil springs.
Post #1068458 26th May 2025 8:28am
J77
I wouldn’t say it’s essential, nothing on the options list is essential. 24MY 90 D250 HSE, Tasman Blue
Post #1068482 26th May 2025 3:40pm
Maverick2810
Evening all, just to say thanks for the responses
Post #1068547 27th May 2025 8:15pm
essentian
I have a 130 which comes with air as standard. Will say that the ride/air is nowhere near as good as my outgoing Q7s (also with air) or even my 3 series touring with variable dampening, despite having considerably more sidewall to work with. Small bump compliance isn't great and it wallows considerably under cornering.
Post #1068600 28th May 2025 11:52am
lightning
Does it not have different modes such as Dynamic, which should reduce body roll?
Post #1068638 28th May 2025 5:16pm
CincyRovers1
United States
Dynamic mode is only standard on the V8 models and OCTA. Otherwise it has to be programmed in with a GAP Tool or using a company that has access to JLR's Pathfinder software. 𝟐𝟎𝟐𝟏 𝐃𝐞𝐟𝐞𝐧𝐝𝐞𝐫 𝟏𝟏𝟎 𝐒 𝐏𝟑𝟎𝟎 (Pangea Green over Acorn/Lunar)
𝟐𝟎𝟐𝟑 𝐏𝐨𝐫𝐬𝐜𝐡𝐞 𝐌𝐚𝐜𝐚𝐧 𝐒 (Dolomite Silver over Black/Bordeaux Red)
𝟐𝟎𝟏𝟕 𝐃𝐢𝐬𝐜𝐨𝐯𝐞𝐫𝐲 𝐇𝐒𝐄 𝐋𝐮𝐱𝐮𝐫𝐲 𝐒𝐢𝟔 (Aintree Green over Vintage Tan/Ebony) - Gone
𝟐𝟎𝟏𝟏 𝐋𝐑𝟒 𝐇𝐒𝐄 𝟓.𝟎 (Ipanema Sand over Almond/Arabica) - Gone
Post #1068639 28th May 2025 5:26pm
essentian
As Cincy said above, only "road" modes are Comfort & Eco.
Post #1068641 28th May 2025 6:22pm
XplusYplusZ
I use my def mostly for annoying cyclists in London.
I like Air sus for:
1. Making access easier for passengers (old folks, pregnant ladies, lazy cockapoos)
2. Getting a little more of a peek over traffic to see what dingbats are up to ahead.
3. It gives me more confidence to squeak into 1.95m carparks in access mode, only to discover there's a tranny van with a roofrack in there.
4. It is a bit more supple than the coils, but it's not as silky smooth as more road focussed air suspended vehicles.
5. Boot loading really heavy crap isn't really helped by the rear 'squat' button, but it gives me joy to use it.
It's also nice to know (especially in today's world of frequent flooding) the air sus will give you a tiny little advantage if you waded a little too deep and you start to float, it will go into tip-toe mode, extending beyond regular off-road height, in the hope it can find a last mm or two of traction.
Post #1068699 29th May 2025 1:45pm
lightning
Are you likely to wade through water more than 80cm deep in the vehicle?
Post #1068711 29th May 2025 3:52pm
Crazymind
What size of tires under your defender?
I have noticed the same on the 130. It is less cushioned and a lot stiffer than the 110. Not a surprise though, half a ton heavier, huge rear over hung. It is more compliant and supple when fully loaded. Also the 130 suffer a lot from vertical movement, like vans, expecially at the back. Not the best engineered version the 130.
Post #1068719 29th May 2025 5:42pm
