Home > General & Technical (L663) > Air Suspension
Page 2 of 2 <12
XplusYplusZ
lightning wrote:
Are you likely to wade through water more than 80cm deep in the vehicle?
Well I thought the limit was 90cm, so we're already highlighting that mistakes can be made where such a feature might help us out!
I definitely wouldn't want to wade anywhere close to the limit, but it can be hard to tell what's happening below the surface - even on a familiar road. This feature isn't something I'd ever want to rely on. But I've driven through lots of floods over the past 3 years. This feature might help if a mistake is made.
Post #1068757 30th May 2025 10:10am
essentian
Crazymind wrote:
What size of tires under your defender?
I have noticed the same on the 130. It is less cushioned and a lot stiffer than the 110. Not a surprise though, half a ton heavier, huge rear over hung. It is more compliant and supple when fully loaded. Also the 130 suffer a lot from vertical movement, like vans, expecially at the back. Not the best engineered version the 130.
255/60/R20 Scorpion Zeros - pressures all looked good in TPS screen, though need to check they’re not on an ‘eco’ setting.
Post #1068761 30th May 2025 11:11am
Page 2 of 2 <12
