Home > Maintenance & Modifications > ACF50
philturn1
2015 Defender 90 Puma 2.2 XS CSW Fuji White
ACF50
Has anyone tried using ACF50 on the inside of chassis rails?
Post #1068463 26th May 2025 10:21am
BrickBox
I use it everywhere apart from near bushes etc (rubber/gaskets etc)
I absolutely rate the product. 2008 2.4 110 Utility Station Wagon XS.
Post #1068465 26th May 2025 10:47am
Ianh
I love AC50, especially on bulkhead bonnet hinge brackets , cappings ets. However for inside the chassis I think Built Hamber Dynax S50 is superior much longer lasting solution.
https://bilthamber.com/product/dynax-s50/
Post #1068474 26th May 2025 1:20pm
Bluest
If notbing else, ACF50 is pretty expensive by volume. For bulk use in a chassis I'd be looking to use something from Bilt Hamber or Dinitrol. 2007 110 TDCi Station Wagon XS
Post #1068485 26th May 2025 4:54pm
steveww
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Bronze Green
I use ACF50 every summer to spray inside the chasis rails. I use the Schutz gun with a wand @ 50psi. I also use ACF50 on various other bits and bobs around the Defender. You can buy it in 4L cans that will last you a long time, a little goes a long way.
BTW it also works well as a penetrating oil to free seized components.
Post #1068516 27th May 2025 11:11am
I’d use Dinitrol with internal straws aerosol or you can use the compressor system if you have one.
This is just a suggestion of course, there are options.
When I did mine, I used brown wax internally and black externally. _\Hennessey|Venom| F5/___
___\⭐️Lone|Star|State/___
____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1068553 27th May 2025 10:58pm
