![]() | Home > Maintenance & Modifications > ACF50 |
philturn1 Member Since: 17 Jul 2015 Location: Hants Posts: 1 ![]() ![]() |
Has anyone tried using ACF50 on the inside of chassis rails?
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2524 ![]() ![]() |
I love AC50, especially on bulkhead bonnet hinge brackets , cappings ets. However for inside the chassis I think Built Hamber Dynax S50 is superior much longer lasting solution.
https://bilthamber.com/product/dynax-s50/ |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4337 ![]() ![]() ![]() |
If notbing else, ACF50 is pretty expensive by volume. For bulk use in a chassis I'd be looking to use something from Bilt Hamber or Dinitrol. 2007 110 TDCi Station Wagon XS
steveww Member Since: 05 Jan 2022 Location: Malton Posts: 611 ![]() ![]() ![]() |
I use ACF50 every summer to spray inside the chasis rails. I use the Schutz gun with a wand @ 50psi. I also use ACF50 on various other bits and bobs around the Defender. You can buy it in 4L cans that will last you a long time, a little goes a long way.
BTW it also works well as a penetrating oil to free seized components. |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21009 ![]() ![]() |
I’d use Dinitrol with internal straws aerosol or you can use the compressor system if you have one.
This is just a suggestion of course, there are options. When I did mine, I used brown wax internally and black externally. ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
