Home > General & Technical (L663) > Tongue weight
nebc100
Luxembourg
Tongue weight
Hello All,
Would anyone here be willing to look on the Certificate of Conformity for the L663 and look at the maximum tongue weight for towing?
I have a P400 and a D5 tdv6 and they are both written as 150Kg but I have the deployable towbar that has a sticker on it saying 350Kg…
I am TRYING to get the right info out of JLR but here in Luxembourg the customer service is done by a 3rd party company who are worse than useless and simply don’t know what they are talking about!!
Thanks in advance
Nick
Post #1067766 15th May 2025 11:04am
Nuclear Nick
From the iGUIDE:
 23.5MY 90 V8 Carpathian grey
Post #1067811 15th May 2025 3:58pm
nebc100
Luxembourg
I know that is what is in the iGUIDE… I wanted to know what is actually marked in your CoC or in your car papers.
The reason is that I have a trailer that is exceeding the 150kg limit and on the JLR site it even says that the deployable bar can take 350kg.
But my CoC says 150kg which would mean that I cannot tow my trailer!!
Post #1067815 15th May 2025 4:17pm
Crazymind
In the UK the legal limit is 150kg. However the same in Aus is 350kg.
With 350 you can tow pretty much anything. Not legally…
Can you not distribute the weight so the nose weight is near the 150kg mark?
What the Heck you have on tow… Smile
Post #1067854 15th May 2025 8:52pm
TexasRover
The town ball weight is recommended to be 5-7%, even 10% of the trailer weight. The max trailer (tow) weight is often limited by county and driver's license laws, but from the manufacturer is probably about 3500kg, meaning about 350kg tow ball weight.
I know in the UK they are more flexible but in mainland Europe most drivers are limited to 3500kg total weight which means about 1500kg Max trailer weight so about 150kg tow ball weight.
Post #1067868 16th May 2025 2:38am
nebc100
Luxembourg
Thanks…
I am towing a 4 horse trailer with a maximum weight of 3500kg
The issue is that on paper everything is good, but when I measured the tongue weight of the trailer (empty) it is already over the 150kg that the CoC of the trailer states.
I then asked LR dealer, and they said it is 350kg maximum, but CS said 159kg like on my CoC for my Def.
I am now in contact with manufacturer of trailer to see how they got it certified like this!!
Thanks for your feedback though!!
Post #1067869 16th May 2025 4:07am
miker
Is your towball at the correct height for the trailer? Makes a huge difference on twin axles.
UK and Europe recommend 4-5% of gross weight on the nose, Australia among others recommends 10%. Hence designed for the 10%.
I've heard of horse trailers that get lighter on the nose when loaded, depending on how the horses load.
Also, I bet once you've loaded 4 horses and associated horsey accessories into your probably 1500kg trailer, you're over 3500kg anyway.
Post #1068048 18th May 2025 9:49pm
TexasRover
In the EU the horses cannot move once loaded. Very important.
Post #1068052 19th May 2025 3:07am
nebc100
Luxembourg
Miker… I know about the tongue weight and am measuring at the right height.
If you read my initial question, I asked if someone could check on their CoC to see what is marked there as here in Luxembourg it is marked as 150kg and I want to see if there is anywhere in Europe (note I am not saying EU) that has it as 350kg like in AU.
Regarding the 3500kg MAM… no… I do NOT exceed it!!
@TexasRover… it is not about the horses moving!! It is because the trailer has a nose weight of 160-180kg even when it is EMPTY so this is not related to the horses moving about!!
I have two choices…
1. Try to get the nose weight on my LRs increase,
2. Get the balance of the trailer sorted to reduce the nose weight.
Since I am looking in to all possibilities, I would hoping that someone on here would have been kind enough to ASSIST and answer the question that I had asked rather than simply make silly unhelpful remarks.
Sorry I was obviously mistaken so I will take back my question and hope that JLR will finally answer with something that makes sense!!
Thanks all the same.
Post #1068075 19th May 2025 4:09pm
Davedig
Put afew bales of hay in the back of the trailer when it’s empty to balance it out!
Post #1068196 21st May 2025 5:45am
nebc100
Luxembourg
I don’t have the small bales…. Just the 500kg ones… so not really a solution.
Also … doesn’t really resolve the matter that the trailer doesn’t conform
Post #1068197 21st May 2025 5:51am
Sulisuli
try using water containers instead......unless you only use IBCs then that wont really help you. 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #1068198 21st May 2025 7:08am
eno
Australia
Would a third option be to move the trailer axles to change the weight distribution? I realise that may not be possible. Also have you checked the tongue weight with different numbers of horses loaded? It might change with load
Post #1068203 21st May 2025 8:17am
Chicken Drumstick
Is it a big name brand trailer or a home brew? Is there a reason it has such a high nose weight empty? Would something like lowering your tow ball (or the entire vehicle) maybe help here, i.e. is your towing point a bit too high and trying to lift the trailer?
Is nose weight something that is checked often where you are? And how are you measuring it? In the UK I'd suggest most people towing have no idea what the nose weight is and would have no means of measuring it.
Post #1068211 21st May 2025 9:39am
lightning
I have two choices…
This is just a general Land Rover forum and people are trying to help by making suggestions. There's no need to be so dismissive of their replies. If it's a grey area you'll need to talk to the manufacturer of the trailer, l am sure they'll have been asked the question before regarding the new Defender.
Post #1068225 21st May 2025 3:20pm
