Home > Td5 > TD5 No start possible ECU - Help πŸ™
LANDROVER
Morning Everyone!
Two weeks ago driving along and my td5 just stopped running.
I checked the basics, under seat relays fuel pump etc.
Everything seems fine.. turning key brings on glow light and engine light as normal. Just doesn't start
Crank sensor is detected using diagnostic tool.
The only thing that jumped out on reading faults was the topside switch fault 😭
Any suggestions on where to send the ECU or suggestions of finding a replacement.
I tried another but I guess they are individually coded to the 10as?
Mine has factory immobilizer the other did not.
Let me know what you suggest as I'm out of action 😭 and need it back running badly. Thank you πŸ™
Post #1067198 7th May 2025 7:54am
MadTom
Czech Republic 1999 Defender 130 Td5 HCPU Baltic Blue
To "just run" the engine, any TD5 ECU will work, but need imobilizer coding (to pair it to 10AS). "Just run" is good only for emergency use, like to get the car out from wood, or move it to workshop, not for longer. It is good to prove, that ECU is the problem.
Top switch fault is probably problem in ECU, but it could be also problem in wires/connectors between ECU and injectors. "Drobek" = The Small One - Discovery 2, "BlufΓ­nek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #1067207 7th May 2025 10:07am
LANDROVER
Thank you for your reply.
I was hoping to try another ECU to prove it before sending this off.
I did unplug and check injector harness and previously replaced it, I have had no misfire etc.
I guess it could be worth putting another on to try.
Just hoping to get it running again as need it back running now 😭
Post #1067225 7th May 2025 12:53pm
RallyRaid
Td5 stopped dead and will not restart
Hello, I have had a similar problem.
I bought a running 2000 110 td5 station wagon as a project (needs a new chassis) and while it is waiting for me to start rebuilding it I start it up and move it about every few weeks. It has always started promptly and run perfectly. Last time I started it easily as usual and left it running for a while to warm, but suddenly it just stopped, and would not restart. I found the main relay fuse had blown and in trying to start it after replacing the fuse I found I then had a problem of main and glow-plug relays clicking repeatedly rapidly, and dash lights looking like a Christmas tree gone mad. In searching for a bad earth or a short I found to my utter shock that the started motor was incredibly loose. I tightened it and found the problem of the repeated rapid relay clicking and crazy dash lights had been sorted. Still, with the characteristic sound of the fueling gurgling and slowly settling, as normal, it would crank with all the dash lights behaving normally, but it would not show any sign of starting. I checked the CPS resistance and wiring right back to the ECU and found they were all good. I cleaned typical Td5 oil creep from the ECU connectors. I replaced relays with new ones. Still, the engine will crank rapidly, with all the usual fueling sounds and dash lights displayed, but there is not even a hint of an attempt to start, like there is no fuel being injected at all. So, does anyone have any suggestions as to what the problem might be? Perhaps an electrical short or earth failure due to the loose starter motor gave the ECU a shock it could not handle, hence the blown fuse and now perhaps the ECU is damaged? Thoughts, people? Thank you.
Post #1067245 7th May 2025 7:51pm
LANDROVER
Any luck RallyRaid with your problem?
I'm still no further forward...
I have checked several things and still nothing.
I checked injectors and can activate with computer.
Fuel pump works and can be done with computer.
Fuel at the for as I cracked it open to check
No warning light on dash
Engine speed reading ok
No faults on diagnostic computer other than tachometer? I guess that's for rev counter which I don't have?
I keep thinking ECU but I'm not keen to record a borrowed one to try incase I mess it up. So might buy a spare but I'm not convinced it's ECU as it communicates fine and injectors activate using computer.
Any other suggestions anyone?
Post #1068008 18th May 2025 9:06am
RallyRaid
I am no further forward, unfortunately.
I am going to send my ECU away for testing.
I will report back what is found.
Fingers crossed I find it is the ECU, and that the ECU can be repaired.
Post #1068011 18th May 2025 10:08am
LANDROVER
Hopefully you find the issue.
It's strange I can communicate with everything but I think like you the problem is ECU related.
I'm tempted to buy another ECU to try if I can manage to copy data across.
Let me know how it goes for you.
Post #1068035 18th May 2025 6:14pm
