![]() | Home > In Car Electronics > car pc fitment |
| markb110 Member Since: 22 May 2010 Location: Guildford Posts: 2704
RAM Mounts used to do a kit to mount the Panasonic Tough Book series laptop into the front of vehicles.
Your police cruisers use them, or something similar. Might be worth looking on the RAM website to see if they have a universal kit, or go for a tablet with a Bluetooth keyboard. Again RAM do the X Grips for tablets. I hope that helps in some way. |
| diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6218
I built a few proper car "PC"'s a few years back using a miniITX format motherboard with a solid state HDD.
Then had a 10" touch screen on the dash. I really liked that setup as I find the files etc easier to navigate over an iPad type of thing. I had music, video files, memory map, RAVE and numerous other tech files on it. Trouble was I nearly ditched my 110 a couple of times when looking at the screen instead of out the window! memory map was probably the best thing on it, but my android does virtually the same thing with backcountry navigator now. |
| AMBxx Member Since: 24 Jul 2016 Location: York Posts: 1073
It would be fun to try a Raspberry PI - one of the smaller ones. You wouldn't even use a regular SSD; MMC is much more compact. Plus, you can run it off USB.
| kyvlle Member Since: 22 Jul 2016 Location: Essex Posts: 79
I'm so tempted! But as OP said, figuring out a good mounting system is really difficult!
