Home > BMW Engine Conversions > 8HP behind a M57N2
carrotbay
United Kingdom 2008 Defender 110 BMW M57 3.0 Diesel XS CSW Auto Santorini Black
8HP behind a M57N2
Hi
I’ve just swapped out my 6HP28X for a 8HP70X and have been trying the get to grips with the CANTCU controller.
The issue I have is I’m not getting a wheel speed value to the TCU. It’s in a Puma so I’m using the HoT M57 to Puma dashboard interface and loom. It was an issue for the 6HP but didn’t make so much if a difference. For the 8HP I’ve had the select wheel speed simulator otherwise it behaves very erratically, holding gears etc.
The question is why don’t I get a wheel speed value in the TCU? Could it be as simple as a wheel sensor or has anyone else had a similar issue with setup?
Thanks. 2008 Defender 110 XS SW - M57N2 / 8HP70X
Post #1067628 13th May 2025 8:34pm
jst
Sorry can't help but interested to follow. What the change 6hp not coping for you? Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1067640 13th May 2025 10:23pm
carrotbay
The 6HP was good for about a year. It developed a couple of issues. Firstly when cold it wouldn’t select 6th for the first mile or so. I then developed a speed related whine which was pretty loud. Initially thought that was transfer box related so swapped that but it was still there.
I’d already started gathering the bits for the 8HP conversion (picked up a very cheap box due to it’s BMW transfer case being damaged etc) and also wanted to make move from the 1.2 transfer box to a 1.1 for a more relaxed cruising speed. So while it was all coming apart anyway decided to move to the 8HP.
Swapping the transmission on the drive with the engine in wasn’t much fun. I think it was easier swinging in the engine, gearbox and transfer box as one lump when I did the initial conversion!
Already it is a much smoother drive and if I can sort the wheel speed issue should be able to improve that further with a bit of tuning of TCU.
Phil 2008 Defender 110 XS SW - M57N2 / 8HP70X
Post #1067648 14th May 2025 5:29am
Linds Hanson
Have you spoken to Kenneth? CANTCU's dad
Post #1067658 14th May 2025 10:10am
tommobot
Can't help either, but with the wheel speed simulator, as long as the diff ratio and tyre size is correct CANTCU seems to work it out pretty faultlessly.
I've got no wheelspeed sensors or any modern bits, so its soley on relying on the simulator but behaves perfectly
Post #1067671 14th May 2025 12:15pm
carrotbay
That’s a good call - I’ll make contact 2008 Defender 110 XS SW - M57N2 / 8HP70X
Post #1067681 14th May 2025 1:11pm
carrotbay
It seems to be okay so far. I’ve calculated the final drive ratio, ie diff ratio and transfer box ratio combined and it seems to work so far. I’ll still chase down the issue with the wheel speed sensor though. An ABS and TCS light popped up this morning so clearly there’s a problem and probably a sensor. 2008 Defender 110 XS SW - M57N2 / 8HP70X
Post #1067685 14th May 2025 1:14pm
Raku52
On 4wd with transfer case vehicles you have to use simulated wheel speed option on cantcu.
Post #1077811 18th Oct 2025 9:42am
