Home > Faults & Fixes (L663) > Creaking/Cracking sound from Rear Door
66north
From the initial silent wafting L663 experience my Defender has developed an annoying creaking/cracking sound that I've managed to trace to the rear door.
Noise sounds to be coming from the door catch area. Tried a squirt of WD40 and some spray grease around the rear door catch/striker and the plastic guide without any success.
Before I head off to the dealer, anyone else had this and know of a quick fix?
Post #925402 12th Oct 2021 10:55am
dizeeduckie
I think you might find it's the rubber trim at the top of the door?
I have it on all my doors but haven't found a solution.
Post #927520 28th Oct 2021 10:23am
Ritson
France
Re: Creaking/Cracking sound from Rear Door
Did you manage to get this diagnosed and repaired? Mine's doing the same now and I'm booked in at the dealers next week... Current: MY22 P400e SE
Prior: Discovery Sport HSE, Jaguar F-Type S, Discovery 3, RR Vogue
Post #937227 11th Jan 2022 4:42pm
zilch
Australia
Same happens to mine, every few months i take it to the dealers to get them to
lubricate the door rubbers. Some people are swearing by Gummi Plfege as a solution,
you can apply it as soon as the creaks return.. not tried it myself though yet Whistle yet another pommie bar steward down under
MY20 110 P400 SE Defender
MY10 3.0 RR Sport
Post #937300 12th Jan 2022 7:47am
vlad
Romania
Every few weeks I have to grease the rubber seals on all the doors and the sunroof.
The LR service uses this exact grease, so I use the same one: https://products.liqui-moly.com/silicone-g...ent-2.html MY2021 Defender 90 P400 SE
Post #938132 18th Jan 2022 8:22am
66north
The sound suddenly disappeared so whether I cured it with the lube eventually doing its thing or it simply cured itself I don't know.
Post #938494 20th Jan 2022 2:38pm
Ritson
France
Took the car to the dealers yesterday. They adjusted the doors and lubed the door seals which has (for the moment at least) solved the issue. Current: MY22 P400e SE
Post #938540 20th Jan 2022 6:17pm
lightning
Mine has a creaking/cracking sound but it seems to be coming from the front somewhere, as yet l've not been able to trace the source of it.
Post #1065251 10th Apr 2025 7:38pm
Wellands
I have an annoying creak/rattle coming from driver door constantly. I’ve applied gummi to all rubber which hasn’t helped. I have a feeling it’s a wire inside the door. Has anyone else experienced similar - thanks
Post #1067499 11th May 2025 6:38pm
eno
Australia
Mine sounds like it has something loose in the driver's door. I first noticed it maybe a month ago but it's getting very regular now with any more than light braking.
Post #1068205 21st May 2025 9:38am
sasa
Czech Republic
I had it too (when light braking), I was unhappy about it, I lubricated all the rubbers, nothing. Then I sprayed oil into the lock and it stopped...strange but helped
Post #1068260 22nd May 2025 7:56am
DazzlerAU
Australia
I have the same click/creak on light braking, sounds like it's in the driver's door. My car takes a beating so I expect a few more rattles 4 years in, actually one rattle has been in my right ear since I bought the car and I've never isolated it, so I just put up with it. But I am curious if greasing the locks makes a difference. What did you spray into the lock?
Post #1070943 6th Jul 2025 11:10pm
sasa
Czech Republic
I tried Sonax for rubber the first, than it helped I asked LR for spraying some their oil. Since this I only sometimes use any oilspray I have.
Post #1070946 7th Jul 2025 7:13am
lightning
Update
lf you have a creaking or cracking noise coming from the front and you can't trace it, it's most likely the two front undertrays.
Take them off and you'll find white residue from oxidation where the bolts hold them on. Spray with grease or similar, re assemble and all will be silent again.
Post #1070958 7th Jul 2025 10:46am
sasa
Czech Republic
could you please specify the bolts?
Something is banging on my axle or front, I think, I had it at LR service and everything was fine, so I would try it, could it be this... Thank you
Post #1071407 14th Jul 2025 12:44pm
