![]() | Home > In Car Electronics > Added Electricals. |
BobGFish Member Since: 09 Jan 2025 Location: Zug Posts: 32 ![]() ![]() ![]() |
Hey all
I have a 2014 Puma. It was used at CERN and 100% had a few electrical mods done. I'm struggling to identify what is original and what was added. I suspect it had small flashing lights front and back and had an added two way radio or the like. I've attached some pictures and have some questions. Is the connector in engine bay normally used? Is the radio aerial normally on the right side? (I have one installed on the left but hole in right wing) Battery box looks like the fuse board and relays were all added? Passenger side looks OK except added piggy back fuse, blue connector, earthing and the two aerial cables? Under cubby hole added plugs? Under cubby hole panel...very hard to tell what's added. Assume the woven cable and dodgy insulation tape are giveaways. Many Thanks ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge |
