Home > Puma (Tdci) > 90 TDCI rear passenger side creaking
458GT
My 90 Softop is making some weird noises around the passenger side rear corner area. Unfortunately the local specialist is unable to review for 4 weeks.
It sounds like a squeal, creak (no knocking nor banging) or as I originally thought a dog in the back! Admittedly it was doing this on occasion, at only low speed uneven road conditions for past 2-300ish miles but it didn't occur to me what / where it was coming from. However now, as soon as I drive it keeps making the noise until I stop.
I jumped on the rear tow bar and it made the noise then and was much located toward the passenger rear corner .
Anything obvious I can do / look at?
Post #1067410 9th May 2025 9:22pm
BrickBox
There’s isnt many bushes on a Defender. So I’d start with shock bushes and A-Frame ball joint. 2017 L494 Range Rover Sport SVR
2008 2.4 110 Utility Station Wagon XS.
Post #1067426 10th May 2025 7:39am
lightning
lf yours is fitted with a rear anti roll bar l have found this often happens with the drop links.
Post #1067449 10th May 2025 4:18pm
458GT
Thanks both Thumbs Up Right it's stopped.. for now.
Please don't shoot me down Embarassed but I sprayed a little WD40 over the offending corners shock absorber bushes and creaks stopped instantly. Perhaps not the correct approach (and google seems to suggest plenty of horror lies ahead Whistle ..) but it's booked in anyway so if anything needs working on it can get sorted then.
Post #1067469 10th May 2025 10:00pm
BrickBox
It’s a good way of process of elimination. No wrong doing there. Sounds like you’ve found the issue quick. 2017 L494 Range Rover Sport SVR
Post #1067471 10th May 2025 10:06pm
