Home > Maintenance & Modifications > Tow Bar removal
Nozza
United Kingdom 2015 Defender 110 Puma 2.2 SW Corris Grey
Tow Bar removal
Hi,
I want to remove a two bar from my 2015 Defender 110, and can see the bolts to remove the tow bar itself, but what is the best thing to do with the connector for the towing lights?
Many thanks,
N
Post #1067342 9th May 2025 11:49am
excossack
You might find its a plug and play setup. From memory the connector hides behind the plastic panel in the wheel arch 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #1067343 9th May 2025 11:52am
Nozza
Thanks - looks like it goes all the way to the front of the car and connects with the electrics and gearbox for reverse lights...for now, I have zip tied it out of the ay, so I can get on with angle grinding and painting the rear cross member and sorting the step. Cheers
Post #1067347 9th May 2025 12:56pm
If it as per factory wiring the towing harness joins the main rear harness via a connector located behind the mudshield to the rear of the rear offside wheel (between the mudshield and the rear tub).
Post #1067367 9th May 2025 3:36pm
Nozza
Thanks blackwolf - this isn't a factory fitted tow bar...there is a cable running from the connector the length of the Defender chassis as far as I can see. Cheers
Post #1067373 9th May 2025 4:23pm
Ianh
As yours is a 2015 Puma Is it a 13 pin trailer socket ? If so the genuine wiring loom connects behind the offside rear arch as stated above, but also goes to the front battery box. Perhaps that’s why you are seeing
Post #1067374 9th May 2025 4:28pm
Nozza
Thanks Ian, it is a 13 pin connector and it looks to be exactly what you say is happening...For now it is zip tied out of the way so I can angle grind the rear cross member and paint it. Just need to decide if I leave it or see how difficult to remove.
Post #1067375 9th May 2025 4:42pm
Ah, I hadn't factored the 13-pin aspect in.
Post #1067379 9th May 2025 5:08pm
I was just going to mention if it was 7 pin or 13, but you all beat me to it.
That adds some more fun to it all having to use adaptors to switch between the two types for sure. Laughing
Ian has answered that correctly I think, and the other connector is located where BW mentioned.
Tbh you can likely safely secure it the socket just out the way with a zip tie I’d have thought. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1067388 9th May 2025 7:02pm
Nozza
Thanks for that…I have zip tied it and it seems to be ok and out of the way
Post #1067428 10th May 2025 8:38am
