![]() | Home > General & Technical (L663) > Swap AJ200D (D200) with AJ300D (D250, D300) engine on L663 |
Moo Member Since: 01 Oct 2021 Location: UK Posts: 1472 ![]() ![]() |
Sounds like it will be better to sell and get what you want.
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 3385 ![]() ![]() |
Heavens that would be a massive job. Although anything is possible. ldeally you would need to find a written off Defender with the 3.0 engine still intact.
As above, better to sell yours and buy the one that you want. |
jojoba Member Since: 03 May 2025 Location: St Albans Posts: 15 ![]() ![]() |
hi - i'm thinking of doing exactly this - so did you manage to find someone or do the swap yourself?
CincyRovers1 Member Since: 30 Nov 2023 Location: Cincinnati, Ohio Posts: 136 ![]() ![]() |
Another thing to be aware of is that the 3.0 diesels have the Active Driveline AWD system that replaces the center differential for a clutch pack and a front axle disconnect. Eventually all Defenders got this drivetrain for the 2020.5MY. The engine might not be compatible with the permanent 4WD system in your current Defender, and of course add on the fact that you'd need to retrofit all of the MHEV components. You're honestly better off getting a new Defender. 𝟐𝟎𝟐𝟏 𝐃𝐞𝐟𝐞𝐧𝐝𝐞𝐫 𝟏𝟏𝟎 𝐒 𝐏𝟑𝟎𝟎 (Pangea Green over Acorn/Lunar)
𝟐𝟎𝟐𝟑 𝐏𝐨𝐫𝐬𝐜𝐡𝐞 𝐌𝐚𝐜𝐚𝐧 𝐒 (Dolomite Silver over Black/Bordeaux Red) 𝟐𝟎𝟏𝟕 𝐃𝐢𝐬𝐜𝐨𝐯𝐞𝐫𝐲 𝐇𝐒𝐄 𝐋𝐮𝐱𝐮𝐫𝐲 𝐒𝐢𝟔 (Aintree Green over Vintage Tan/Ebony) - Gone 𝟐𝟎𝟏𝟏 𝐋𝐑𝟒 𝐇𝐒𝐄 𝟓.𝟎 (Ipanema Sand over Almond/Arabica) - Gone |
Yadub Member Since: 02 May 2025 Location: La Rochelle Posts: 7 ![]() ![]() |
Years ago, I swapped my RR 4,6l V8 engine with a stripped engine from "Turner Engineering" including Heads, with new block, front cover, Oil Pump assembly, etc... But not sure they sale 3.0 ingenium, TBC.
https://www.turnerengineering.co.uk/ |
