![]() | Home > Tdi > Unable to start 200tdi |
| jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8365
I'd relook at timing belt assuming you have fuel. How long did it run for after changing belt? Cheers
| MarkBrown Member Since: 03 Oct 2022 Location: Mid Wales Posts: 563
Air lock in the fuel line? Assuming the timing is correct, as said above. 1983 110 automatic OM606
| landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5986
Are you sure you have enough fuel, at enough pressure?
Have you got power to the fuel cutoff on the pump? Is it working correctly? I would stick some brake cleaner down the air intake and see if it runs on that. If it does you have a fuel problem. |
| Joeytf Member Since: 20 Sep 2024 Location: Somerset Posts: 39
Didn’t run for long as had a leak, probably around a minute in total but had no indication it was coughing or low on fuel. Will try an easy start and see what happens.
Still won’t run
did it stop on own or you started it? will it tow start? Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
| Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2378
Recheck your timing and check it again. If the timing is right it just needs fuel and air to run, they're simple engines.
I can’t really tow it from where it’s parked, I’ve put a pipe from the lift pump to a jerry can of fresh diesel. Would a starter motor on its way out stop it? |
| julian Member Since: 17 Feb 2017 Location: Devon Posts: 185
Have you reached the timing? As in pinned the fly wheel and the pump again?
It's 3 bolts to take off the inspection port, so, if you have not done it, it's #1 on the task list. Also - Had this been a running motor prior, or had it been parked up for months / years? |
If it won’t run whilst squirting brake cleaner down the air intake, it’s not a fuel issue you have. Check your timing |
Looking like timing needs a recheck. These are pretty simple engines, if it's.got fuel and air then its lacking compression at right time. Cheers
| Linds Hanson Member Since: 16 Jan 2021 Location: Cornwall Posts: 529
Take the front off and recheck the valve and injection timing, don't keep trying to start it until you have confirmed the timing is correct. Some brake cleaner isn't combustible.
