![]() | Home > Puma (Tdci) > Abs, Traction Control and handbrake light on |
BrickBox Member Since: 05 Oct 2021 Location: Wales Posts: 1049 ![]() ![]() ![]() |
For some reason, I find Autel has issues communicating with the ABS module. I could hardly ever get codes for any abs issues. It’s just advice that it could be the reader, not the abs at fault for not giving codes.
As soon as I plugged a higher quality reader in, I had codes straight away. 2017 5.0 V8 Supercharged RRS SVR 2008 2.4 110 Utility Station Wagon XS. |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2510 ![]() ![]() |
You did not state which Puma you have ! The 2.4 has a Wabco ABS unit and the 2.2 has a Bosch.
A Nanocom can communicate with the Wabco but not the Bosch. |
John P Member Since: 26 Dec 2013 Location: West Sussex Posts: 363 ![]() ![]() ![]() |
I had the same issue on my 2.4 Puma. First thing I did was check the fuse, and for some reason it was blown. Replaced the fuse and have never had a problem since. Fuse is under the drivers seat.
jbcollier Member Since: 29 Apr 2024 Location: Edmonton AB Posts: 268 ![]() ![]() ![]() |
Reliable ABS code reading only comes from dedicated Land Rover scanners from Nanocom, IIDT Tool (Gap Diagnostic), etc.
Minch90 Member Since: 15 Sep 2017 Location: Gloucestershire Posts: 245 ![]() ![]() |
Same as JohnP when this happened to me - big pink fuse under drivers seat blown. Followed advice from here found chaffed cable behind master cylinder with signs of a short, fixed this, replaced fuse and all is good 2.4TDCI 90 - everyday brilliance
S3 V8 Lightweight - in the garage being ignored #newchassistime S3 lightweight - 2nd car 24V fire risk with a full tilt and the windscreen down S1 80" - first car fun - 75mph in neutral downhill once #wobblesallround |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8396 ![]() ![]() ![]() |
Early 2.4 upto 10MY have wabco systems. 10my onwards all Bosch systems.
My atuel connects no probs with abs modules across a range of vehicles including my defender. Maybe a software update needed? Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
