Home > Puma (Tdci) > Abs, Traction Control and handbrake light on
Marshall10488
United Kingdom 2010 Defender 110 Puma 2.4 XS CSW Stornoway Grey
Hi, I'm after some advice. Yesterday my handbrake, TV and ABS lights came on while driving.
I've plugged my autel OBD reader in to see if it was an absolute sensor but it now can't communicate with the abs control module.
I assume that points to the abs control module having gone rather than the pump or sensors? How do I know which control module mine takes? Did this with my BMW and even though they are same year and model they all have different control.modules, are the defenders the same?
Thanks in advance
Post #1066673 30th Apr 2025 9:25am
BrickBox
For some reason, I find Autel has issues communicating with the ABS module. I could hardly ever get codes for any abs issues. It’s just advice that it could be the reader, not the abs at fault for not giving codes.
As soon as I plugged a higher quality reader in, I had codes straight away. 2017 L494 Range Rover Sport SVR
2008 2.4 110 Utility Station Wagon XS.
Post #1066674 30th Apr 2025 9:35am
Ianh
You did not state which Puma you have ! The 2.4 has a Wabco ABS unit and the 2.2 has a Bosch.
A Nanocom can communicate with the Wabco but not the Bosch.
Post #1066678 30th Apr 2025 10:22am
John P
United Kingdom 2012 Defender 90 Puma 2.2 SW Corris Grey
I had the same issue on my 2.4 Puma. First thing I did was check the fuse, and for some reason it was blown. Replaced the fuse and have never had a problem since. Fuse is under the drivers seat.
Post #1066692 30th Apr 2025 12:39pm
jbcollier
Canada 2009 Defender 110 Puma 2.4 SW Alpine White
Reliable ABS code reading only comes from dedicated Land Rover scanners from Nanocom, IIDT Tool (Gap Diagnostic), etc.
Post #1066704 30th Apr 2025 1:46pm
Minch90
Same as JohnP when this happened to me - big pink fuse under drivers seat blown. Followed advice from here found chaffed cable behind master cylinder with signs of a short, fixed this, replaced fuse and all is good 2.4TDCI 90 - everyday brilliance
S3 V8 Lightweight - in the garage being ignored #newchassistime
S3 lightweight - 2nd car 24V fire risk with a full tilt and the windscreen down
S1 80" - first car fun - 75mph in neutral downhill once #wobblesallround
Post #1066711 30th Apr 2025 3:45pm
jst
Early 2.4 upto 10MY have wabco systems. 10my onwards all Bosch systems.
My atuel connects no probs with abs modules across a range of vehicles including my defender. Maybe a software update needed? Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1066722 30th Apr 2025 6:57pm
