Home > Td5 > Ashcroft 1.2 transfer box
2hel
United Kingdom 2003 Defender 90 Td5 CSW Java Black
Morning all,
I think I'm finally ready to push the button and order the ashcroft 1.2 transfer box for my 90 TD5.. though I am onnthe fence about paying the extra for a 'sleeved' casing? Is it worth the extra for those that have gone with it? Generally I use the defender on the road maybe 3k miles a year, I'm just sick of driving at 60mph on the motorways so hoping the 1.2 let's me sit at 70mph easier.
Thanks all
Post #1066580 29th Apr 2025 8:54am
jst
If the engine has the grunt and ratios for rpm work then it will be a good upgrade.
After having the middle shaft bushing fail on a 73k puma I go for sleeved now. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1066584 29th Apr 2025 9:14am
2hel
It's got a stage 1 Alive tuning remap so hopefully the low end will be OK with the 1.2
Post #1066587 29th Apr 2025 9:35am
rustandoil
I went for the sleeved option....and while I was ordering, ticked every other option too!! Rolling with laughter
Post #1066597 29th Apr 2025 12:19pm
jst
Depends on lots more, run it though ashcroft calculator and see if revs are in right range, if so good to go. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1066609 29th Apr 2025 1:46pm
2hel
Oh don't say that I've gone and placed the order Laughing
I'll have a double check thanks mate
Post #1066623 29th Apr 2025 6:31pm
jst
Unless you have oversized tyres, run heavy, tow alot.on hilly areas and have roof rack loaded up and are on std diffs I am sure it will work fine. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1066625 29th Apr 2025 6:39pm
2hel
I do have oversized tyres 265/65/18
Ran the calculator on their site and seems it should be a noticeable difference with motorway speeds which is the goal Thumbs Up
Post #1066630 29th Apr 2025 8:26pm
jst
200rpm per 10mph? Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1066639 29th Apr 2025 9:13pm
jst
200rpm per change for 1.4 to 1.2? Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1066640 29th Apr 2025 9:13pm
TexasRover
The R380/Td5 runs fairly high revs in stock at motorway speeds and comfortable can take another gear. I have a roamerdrive installed and mostly drive in '6th gear' above 55-60 mph no problem.
The problem with the 1.2 box I expect is in the lower gears where you start loosing overlap and find yourself searching for the right gear at certain speeds (3rd-4th). I am sure you get used to it.
When I got my Series it has two RR diffs (3.54) and it was awful to drive. I swapped it back to standard 4.7 diffs, much happier. You don't go far or fast in a Series so it does not matter that much.
Good luck, it will be fine.
Post #1066643 29th Apr 2025 9:26pm
barbel jim
It’ll be absolutely fine, you’ll love it, and yes the sleeved option is worth it, especially if it’s a keeper. I’m awaiting the arrival of my new transfer box from Dave
Post #1066655 29th Apr 2025 10:08pm
andy2111
United Kingdom 2002 Defender 110 Td5 HT Bonatti Grey
I have the 1.2 ratios and am running an Alive GTB 450 turbo and custom remap giving me 185 bhp (I deliberately kept the tune on the low side of what's possible). So plenty of power for the 1 2 transfer box.
On motorways the 1.2 ratios are awesome and so long range cruising and fuel economy is great.
I find pulling away in 1st a bit of a faff as it needs extra oomph to get going. I have to rev higher than feels natural to pull away and build speed progressively. If I don't build the revs up I move a bit before it loses momentum which then builds up again as you pull away. Not ideal when pulling away into traffic and not picking up as quickly as you and other vehicles expect!
Clearly can be resolved by changing how I drive it, but thought I'd share my experience with it. TD5 hardtop to Puma inspired Poptop - my build thread
2002 110 TD5 Hardtop ¦ Full Puma interior ¦ Carpathian grey / Santorini black ¦ X-Vision-X poptop
Post #1070381 26th Jun 2025 6:32pm
Oldowner
I ran a 1.2 box in a 300tdi 90 for fifteen years, did close to 100,000 motorway miles with it, transformed the vehicle for that use. I still have it but it’s long been relegated to boat launching and it’s still got the 1.2 box in (which is actually sleeved!). I was thinking about changing it back to 1.4 or the now available 1.3 ratio but haven’t actually bothered as it’s still perfectly useable.
I have always rebuilt LT230’s myself, but get Ashcroft to sleeve the casing as they are always worn. I also put in one piece diff spider and HD intermediate shaft as again these always have wear on them.
Post #1070399 27th Jun 2025 6:23am
