![]() | Home > Modifications & Maintenance (L663) > 4X4 Predator Wide arches fitted |
Colin68 Member Since: 18 Jul 2024 Location: Blackpool Posts: 125 ![]() ![]() |
Fitted new wide arches to my Defender yesterday. I did order different 3m VHB tape and adhesive promotor which made fitting far easier. makes the car far meaner looking.
https://www.defender2.net/gallery/albums/u...-25-57.jpg |
CarMan Member Since: 29 Nov 2010 Location: Cotswolds Posts: 1902 ![]() ![]() |
I think this is it, which was in his gallery
![]() Click image to enlarge Rob 1993 200tdi 90 hard-top 1998 300tdi 90 soft-top |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 3351 ![]() ![]() |
Yeah l think it looks good in black with the extended arches.
Down & Dirty Member Since: 15 Sep 2023 Location: Somewhere outback Posts: 95 ![]() ![]() |
Liking the look
![]() So much so just ordered a set ![]() Any tips hints for removing old ones and installing new ones greatfully received ![]() |
Don't use the tape supplied. I bought 3M VHB 5952 tape of Amazon. The old trims just pull off.
I watched the you tube video by Powerful UK which shows you how to fit them. |
Excellent thanks for the info
XIX Member Since: 23 May 2025 Location: Perth Posts: 1 ![]() ![]() |
Hi, was there a particular width of the 3m tape you got? Mine came with some scotch clear double sided about 8mm wide, Im thinking of getting some 20mm 3m tape to give it much better contact patch but unsure? |
