Home > Tdi > Battery light on after new alternator fitted?
KiwiNCFC
United Kingdom 1997 Defender 90 300 Tdi HT Arles Blue
Hi guys,
I've just fitted a new genuine Hella 300tdi alternator to my defender and it's doing a weird thing...
When I start the car the battery light is illuminated and there is 12.8v at the battery. As soon as I blip the throttle the battery light goes out and I have 14.4v at the battery.
The old alternator obviously never did this but does anyone know why it's doing this? It's just odd. [/list]
Post #1066461 27th Apr 2025 2:27pm
Ianh
What you are doing by blipping the throttle is exciting he alternator, which then causes the alternator to work.
I’m not familiar with the 300TDI alternator wiring, however alongside the heavy gauge wire going to the battery you should also have at least one small gauge wire. This wire should apply 12v to the alternator when the ignition is on and is used to excite the alternator without the need to blip the throttle.
I would look at the wiring diagrams and check this circuit out as your first investigation. Making sure you have terminated this wire correctly when you replaced the alternator.
Here is the diagram , the yellow / Brown wire from the instrument cluster goes to a diode (G126), a Brown/ yellow wire from the diode goes to the alternator. This should excite the alternator when ignition is switched on. So you need to test the 12v is getting to the alternator. If not check the wires and diode.
https://www.lrworkshop.com/wiring-diagram/...ing/300tdi
Post #1066463 27th Apr 2025 3:18pm
GeorgeE
United Kingdom 1991 Defender 110 200 Tdi CSW Venetian Red
Re: Battery light on after new alternator fitted?
KiwiNCFC wrote:
Hi guys,
Did you keep the same pulley? It isn't that uncommon for the Lucas alternators to need a bit of waking up, I wouldn;t worry about it.
Post #1066521 28th Apr 2025 11:51am
GeorgeE
If that wire wasn't connected properly the charge warning light wouldn't be coming on so I think that is all good.
Post #1066522 28th Apr 2025 11:52am
jst
So alternator is only working when accelerator is pressed? Ie battery light goes out when pressed but comes back on my pedal released?
Ie light doesn't stay out after initial excitement and battery voltage drops to 12.8 from 14.4? Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1066541 28th Apr 2025 3:48pm
KiwiNCFC
Thanks for all your help guys, appreciate it.
I checked for 12v at the alternator on that smaller gauge wire and I had no voltage (with the ignition on).
I then turned the engine on and I only had 2.4v on that wire which was weird and the battery light was illuminated and battery voltage was 12.8v and not rising.
I blipped the throttle and then I had 12v at that wire and then battery voltage was rising to 13.3v+.
I then read some other throwaway comment on another post on this forum regarding alternator issues and someone suggested replacing the bulb for the battery light. Now, I had replaced all my bulbs for LED versions around a year ago so I bought a standard halogen bulb and fitted it and tested for voltage at that small wire with the ignition on and I now had 12v! I then started it up and battery light was not illuminated and I had 13.4v+ on the battery!! So it was down to an LED bulb! I suspect the load of the bulb needed to be seen by the alternator? (Specifically the little electronic module stuck on the back of the alternator?)
Just thought it was worth updating for people in the future but still doesn't explain why it's only started having this problem since the new alternator?? I did replace it because I kept getting a flat battery so possibly the alternator was failing anyway and thus it wasn't really relying on that bulb in the first place.
We live and learn!
Post #1066646 29th Apr 2025 9:29pm
GeorgeE
The current through the no charge lamp excites the alternator to get it charging, if you fit an LED the current will be lower so the alternator will struggle to start charging (in fact I am surprised it worked at all!) hence why you needed to blip the throttle. Once it is charging the current down the wire drops to 0 (and hence the lamp goes out). I know there was a mod on some alternators to put a resistor across the terminals so that if the no charge lamp fails or is on a dashboard with LED warning lights (think it was some 80's VW cars) the alternator will still charge, possibly that resistor was fitted on your old one.
Post #1067217 7th May 2025 11:07am
Procta
where is the diode located? I am suspecting my dad may have blew this a couple of years ago, his is doing the exactly the same thing. He changed the alternator for a more powerful one, but fried the unit some how, and dusted the loom with it. An auto sparky sorted the problem out, then we fitted a replacement alternator. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
In the words of my Good Friend, Gary Forrest 1980 -2025
" we will work something out"
Post #1071655 18th Jul 2025 12:08am
Fossil
United Kingdom 1997 Defender 110 300 Tdi CSW Coniston Green
So the moral of the story is: if you fit a LED battery bulb, fit a parallel resistor to mimic the original incandescent bulb. I think the looms do already gave a parallel resistor to handle the dead bulb scenario, but maybe the OPs Hella alt needed more current
Post #1072967 7th Aug 2025 9:23pm
