Home > Puma (Tdci) > No nipples?
jim4244
England 2013 Defender 90 Puma 2.2 CSW Fuji White
No nipples?
Hi all
Just been under a 2013 Defender 90, 2.2 and there are no grease nipples on the front or rear prop shafts? The nipples are present on the UV joints but none on the shafts..
Is this normal on later model Defenders?
Jim
Post #1066347 26th Apr 2025 9:45am
Yes.
Post #1066351 26th Apr 2025 9:54am
BrickBox
Yes. Later models didn’t have any. 2008 2.4 110 Utility Station Wagon XS.
Post #1066354 26th Apr 2025 10:10am
jim4244
Hmmmm… So another great “sealed for life” idea?
Without replacing the shafts is there a method of getting grease into them?
Jim
Post #1066355 26th Apr 2025 10:16am
andy63
I greased my prop splines..either pop the rubber dirt seal or use a syringe and thin pipe eased under it..either way you can get grease into it..
I think from memory mine were dropped off at the time I did it.
Post #1066363 26th Apr 2025 10:59am
piechipsandpeas
Australia 2013 Defender 110 Puma 2.2 SW Indus Silver
If you remove the prop shaft you can then pop off the rubber boot and slide the two halves apart to check the condition and regrease the bearings. Just make sure to mark the orientation of the two halves so they go back together the same way, thus keeping the phasing of the u-joints as they were.
Post #1066381 26th Apr 2025 2:50pm
Why did LR change to not having a nipple on the slider?
Mine has one on each there…
I’d have thought it was easier to have it than not have one, just so long as it isn’t overdone.
(Too much grease out in).
Perhaps so be people were pumping in far too much in the sliding joint, causing issues there.
Where it should be just some put in the sliding joint if a nipple / zerk is fitted. _\Hennessey|Venom| F5/___
___\⭐️Lone|Star|State/___
____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1066400 26th Apr 2025 6:48pm
Mo Murphy
The only time Land Rover changes anything, its either to make more money or to save money
50 Shades of Pennine Grey
Post #1066413 26th Apr 2025 8:34pm
MK
- As log the rubber boot is in good condition, no need to regrease. With time the rubber will crack.
- You can tap 2 grease nipples, eack on opposite sides.
PD. That tiny 3 grams rubber boot costs around 20GBP Puma 110" SW
Post #1066456 27th Apr 2025 1:21pm
jbcollier
Canada 2009 Defender 110 Puma 2.4 SW Alpine White
If you have ever taken a slip-joint apart, you'll know that a single grease nipple doesn't do much. Every one I've had apart has no way for the grease to get to more than just a few of the splines. Better to take it apart occasionally and grease it properly.
Post #1066495 28th Apr 2025 3:39am
andy63
I'm curious, as I've had my shaft apart and it not actually what I would call a splined connection.. on a late puma it's about a dozen slots that are occupied with ball bearings held in place by a plastic cage.. no idea if that's a standard or if earlier couplings are actually machined mating splines..
Post #1066510 28th Apr 2025 9:13am
jbcollier
Stock shafts, yes. Aftermarket, no.
Post #1066527 28th Apr 2025 1:23pm
andy63
So I'm not getting it wrong...my prop was original.. it had a series of grooves and a ball bearing cage..
Are you saying aftermarket props are actually splined?
Post #1066529 28th Apr 2025 2:00pm
