Home > Td5 > Oil in water td5
Dover mike
England 2000 Defender 90 Td5 CSW Arrow Red
Oil in water td5
Good morning all I have a TD5 and just gone to check levels and noticed that it’s what looks and tells like oil in the water bottle I am thinking this is more then likely head gasket gone it’s a td5 10p I do about 20000 miles a year in it what’s your thoughts on am I correct still running very well if it is the head gasket might as well change over dowels
Post #1066346 26th Apr 2025 9:30am
The oil cooler is another possibility.
Post #1066348 26th Apr 2025 9:54am
Dover mike
ohhhh ok is they anyway of finding out what has failed
Post #1066360 26th Apr 2025 10:47am
I had that on one I built a few years back. changed the head etc, it still did it.
Turned out to be the oil cooler. I removed it (quite easy IIRC), and to test it, got a couple of bolts that fitted the union thread, drilled one right through the centre, tapped it and fitted an airline fitting. putting the plain bolt into the other hole of course! Then attached airline, stuck it in a bucket of water, hey presto bubbles....
I've still got the bolts here somewhere if you want them (no longer have a defender so no use to me)
Post #1066387 26th Apr 2025 4:22pm
derbywill
England 2005 Defender 90 Td5 XS CSW Java Black
Oil cooler will more than likely be the suspect.
Will 2005 90 XS
1954 86'' Series 1 tilt
1968 88” 2A 200tdi
2002 110 Hardtop
Post #1066414 26th Apr 2025 8:51pm
Penfold_6290
United Kingdom 2002 Defender 110 Td5 CSW Epsom Green
Oil in water is more likely to be a failed oil cooler than a head gasket. I discovered the exact same goopy mess the other day on my 120,000 mile 15P after an unplanned radiator removal. I am currently waiting for parts to change the oil cooler and water pump (and exhaust manifold while I'm at it). Not a complicated job and can be carried out without removing the exhaust manifold, but the turbo would need to come off to give you access. I'm only doing the manifold because it's blowing and thought I might as well while the turbo is off.
Post #1066483 27th Apr 2025 9:44pm
As a side note.... I cleaned the oil out of the water by adding some washing powder to the header tank.
do 10 miles or so, drain it, refill & repeat until the water stays clear. Took about 4 or 5 flushes but did the job.
Post #1066484 27th Apr 2025 9:46pm
Dover mike
thanks all i have just ordered all that's needed for replacement oil cooler
Post #1066528 28th Apr 2025 1:34pm
Dover mike
good afternoon all i have ordered all the parts needed do you think i would need to remove the water pump to clean out all the oil or just keep flushing the system through what do you think is the best to flush the system
Post #1066602 29th Apr 2025 12:39pm
derbywill
To be fair if you are stripping it to get the cooler out, I would be changing the water pump.
Will 2005 90 XS
1968 88” 2A 200tdi
2002 110 Hardtop
Post #1066700 30th Apr 2025 1:22pm
As I mentioned above, I was suggested to use washing powder (which breaks down oil) and it worked a treat.
Post #1066731 30th Apr 2025 8:52pm
Dover mike
thanks mate the wife is picking loads up today
Post #1066765 1st May 2025 1:30pm
