![]() | Home > Puma (Tdci) > 2.4 Turbo to Exhaust Gasket |
Kevlar Member Since: 28 Oct 2020 Location: Prague Posts: 84 ![]() ![]() ![]() |
I was informed by island 4x4 that there is no gasket listed for this joint.
I just used some exhaust paste on mine and it doesn’t seem to leak. |
I confirm, no gasket... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
![]() IID Pro MV License |
nickhodgson Member Since: 08 Dec 2009 Location: Zambia Posts: 174 ![]() ![]() |
Thanks Guys 1995 300tdi Defender 90 P/UP
2011 Puma Defender 130 D/C 2000 300tdi Defender 110 P/UP 2015 Discovery 4 SDV6 HSE |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2423 ![]() ![]() |
I wonder what Lr use as the sealant ?
Ps. I also wondered what part 13 was, and saw it was “Anti-squeak grease” which made me smile ![]() ![]() |
InternationalDBA Member Since: 18 Feb 2018 Location: West Sussex Posts: 37 ![]() ![]() ![]() |
I have the 2.4 engine in a 2008 Defender.
I first removed it in 2016 to change the clutch but there was no gasket. I removed it again in 2019 to rebuild the engine. I am currently refitting it now following a chassis change. I saw some gaskets available online and queried this with my supplier (Brook Street Garage, Cuckfield). They checked with one of their mechanics who has worked on several of these engines and he confirmed that these engines never had gaskets. The ones available online may be there for owners who want to fit a gasket but they are not required. |
IanH - Yes, that’s the grease I was on about in a tiny tube as well.
In effect it’s just high temp ceramic grease, to be honest I’m still not sure grease is ideal for that as it will gum up anyway and lead to laggy performance. It might be fine at first, but over time gets sticky, which why I use a bit of 3 in 1 on a regular basis. ![]() ___\⭐️Lone|Star|State/___ ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
DBGID Member Since: 16 Sep 2023 Location: North East Posts: 1 ![]() ![]() ![]() |
There is a square copper(?) gasket on mine. 2008 2.4l. In the Haynes it says recover the gasket discard and replace but like yourselves I cant find a LR part number.
The price of the grease has gone up. Nope! |
bear100 Member Since: 22 Mar 2010 Location: South Wales Posts: 2021 ![]() ![]() ![]() |
There is a copper gasket on mine 2010 2.4, rebuilt the head recently and reused the old gasket just added some Holts firegum assembly paste
![]() 2016 Range Rover Autobiography 4.4 TDV8 (gone) 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1856 ![]() ![]() ![]() |
New Garrett turbos come with a gasket.
HTH Keith |
