![]() | Home > Puma (Tdci) > Leck transfer box |
Vmax Member Since: 29 Apr 2023 Location: Europe Posts: 77 ![]() ![]() ![]() |
I have a oil leak coming from top of the transfer box any idea where is coming from?
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20912 ![]() ![]() |
Is the filler plug loose or in place ? _\Hennessey|Venom| F5/___
___\⭐️Lone|Star|State/___ ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
Thank you very much for help l will check that filter plug.
piechipsandpeas Member Since: 12 May 2021 Location: Albany, Western Australia Posts: 230 ![]() ![]() ![]() |
If it’s from the top of the box it could be from the breather banjo bolt. Like MK says, try removing the cubby box and the access cover from inside the vehicle which will allow you to see directly onto the top of the transfer bo to make identification of the source of the leak easier. It only takes a few minutes to do.
Noted cheers for the advice.
jbcollier Member Since: 29 Apr 2024 Location: Edmonton AB Posts: 253 ![]() ![]() ![]() |
The usual "upper" leaking point is at the front between the front output housing and the transmission. It is the shaft that supports the intermediate gear cluster. It is sealed by an o-ring and is not properly located. This allows a bit of movement that gradually wears the bore and then the leaks start. You can clean it off and coat it with sealer but that is just temporarily masking the problem. The T/C needs to come out, be stripped, and the machined for a steel sleeve. Ashcroft sells the repair sleeves.
Thank you very much 🙏 sorted.
