Home > Maintenance & Modifications > Extended Wheel Arches - Britpart +40mm?
Harry.O
United Kingdom 1989 Defender 90 300 Tdi ST Nato Green
My 90 is due to return to the road after a 10 year hiatus and will require extended wheel arches to pass an MOT.
I'm not keep on the versions that require self-tappers through the body work and would like some that are flexible - the original arches were a flexible material and could be trimmed with a stanley blade however the replacement copies I purchased for the rebuild were brittle and crack or snap when dragged around trees etc. I ripped one off just the other day, at a P&P site.
Does anyone have any experience with the +40mm version by Britpart? Are they brittle or flexible? Do they infill the gap between the front wing skin and the inner wing?
https://www.lrparts.net/lrc1418-set-of-fou...O8QAvD_BwE
Thanks in advance, Harry 2005 Td5 110 Hardtop
1989 300Tdi 90 Soft top
1992 200Tdi 90 Truck cab with Land Cruiser axles
Post #1064833 6th Apr 2025 12:04pm
Race.it
Spain 2010 Defender 110 Puma 2.4 SW Alaska White
Hi, you need to cut the front normal trim up to get the whole filled in the front wheel arch, they pop straight on after that. Searching for my first Defender...and started just as Covid hit, so talk about timing.
5 months after starting the search I found it, and here is the details
Post #1064988 8th Apr 2025 11:26am
Harry.O
Thank you Race.it, that's very helpful Thumbs Up
Any idea if they are the brittle type of plastic or do they have a bit of flexibility? 2005 Td5 110 Hardtop
Post #1064990 8th Apr 2025 12:15pm
Race.it
They are flexiable, you can hit a tree and the pop back, not that I have tested that 😂😂😂 Searching for my first Defender...and started just as Covid hit, so talk about timing.
Post #1064991 8th Apr 2025 12:16pm
