Home > Maintenance & Modifications > DRL Module
roche1800
DRL Module
The problem I have is a wired my DRL’s last year and used an ebay DRL module which worked fine, the DRLs turned off after 15seconds.
After a period of the time the delay got longer and longer.
Fitted new module and tested it in the day and all good, then on Tuesday night (lights on off steering stalk) they would not turn off.
Here’s a pic of the ebay listing and my wiring which shows new yellow coming in from RHS.
What’s the issue?
Post #1064056 27th Mar 2025 7:33pm
roche1800
They cost about £4 each module.
Post #1064057 27th Mar 2025 7:34pm
TexasRover
There's your problem.
If the concept works for you get something better (more expensive)
Post #1064070 27th Mar 2025 8:55pm
Mo Murphy
What does the module do ?
50 Shades of Pennine Grey
Post #1064082 27th Mar 2025 10:03pm
steveww
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Bronze Green
I wired the DLR off the ignition with a relay. Simples.
Post #1064410 1st Apr 2025 12:35pm
TexasRover
Mo
It seems to be a voltage dependent switch so I assume it will detect engine running or not and then there is a timer relay built in as well as a headlight delay (just looking at the picture).
Obviously it's not that hard to distinguish between the car in use and at rest (contact switched power galore) and also a timer relay is easy enough to include in s circuit around the headlight switch, but one of the pitches of this device is the ease of installation: plumbed right at the battery, where presumably the same convenience orientated end user has wired in his radio, amp, fan, coffe machine, etc.
On top of that it seems to be failing quickly, so in that basket of AliExpress: nice idea cheaply executed
Post #1064413 1st Apr 2025 12:59pm
Mo Murphy
As did I with a n/c relay to switch them off when I switched the side / headlamps on.
Thanks for the explanation, Texasrover Thumbs Up
Post #1064414 1st Apr 2025 1:15pm
