![]() | Home > Maintenance & Modifications > DRL Module |
roche1800 Member Since: 07 Apr 2020 Location: derbyshire Posts: 424 ![]() |
They cost about £4 each module.
TexasRover Member Since: 24 Nov 2022 Location: Paris Posts: 1322 ![]() ![]() ![]() |
There's your problem.
If the concept works for you get something better (more expensive) |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2389 ![]() ![]() ![]() |
What does the module do ?
steveww Member Since: 05 Jan 2022 Location: Malton Posts: 611 ![]() ![]() ![]() |
I wired the DLR off the ignition with a relay. Simples.
It seems to be a voltage dependent switch so I assume it will detect engine running or not and then there is a timer relay built in as well as a headlight delay (just looking at the picture). Obviously it's not that hard to distinguish between the car in use and at rest (contact switched power galore) and also a timer relay is easy enough to include in s circuit around the headlight switch, but one of the pitches of this device is the ease of installation: plumbed right at the battery, where presumably the same convenience orientated end user has wired in his radio, amp, fan, coffe machine, etc. On top of that it seems to be failing quickly, so in that basket of AliExpress: nice idea cheaply executed |
As did I with a n/c relay to switch them off when I switched the side / headlamps on. Thanks for the explanation, Texasrover ![]() Mo The Land Rover 90 - Many are called, few are chosen. 50 Shades of Pennine Grey |
