![]() | Home > Modifications & Maintenance (L663) > Retrofit 11.4 Pivi Display |
ThunderBob Member Since: 23 May 2024 Location: Kentucky Posts: 20 ![]() ![]() |
@KeY-8
The display is just held by the four plastic clips. I have indeed removed it after installation; it requires a strong pull to to dislodge. You pull it straight out. Disconnecting the battery is always recommended, I did not disconnect my battery when I installed mine. However I did wear a wrist grounding strap when I unplugged the original display and when I plugged in the new display. Remember the screen powers up sometimes even when you haven’t pressed start button. I have not encountered the blank screen issue but be aware that you may encounter a blank screen if you change the CCF file before you access the hidden menu to change the internal configuration to 11.4 ![]() Click image to enlarge I don’t believe the recall would apply to the new display. Good luck! |
LostCause Member Since: 07 Jan 2025 Location: Toronto Posts: 12 ![]() ![]() |
I’ve not had the blank screen issue either. That said there is an open recall requiring update at the dealership. The update is for “image processor A” I don’t believe this is inside the actual screen.
Fifth Horseman Member Since: 08 Mar 2011 Location: Lanarkshire Posts: 339 ![]() ![]() ![]() |
The Image Processor Module A (IPMA) is the camera module mounted behind the rear view mirror which provides the lane keep assist and traffic sign recognition functions. Defender 110 D300 X-Dynamic HSE MY22
Defender 110 Station Wagon 2011 (gone) Defender 110 DCPU 2007 (gone) |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 3336 ![]() ![]() |
l actually think the vehicle interior looks worse with the larger screen. The small screen looks like it's supposed to be there rather than stuck out in front as the larger screen is.
But that's only my opinion. I am obviously in the minority as most owners nowadays want the large media screen. At least there will be plenty of 10" screens on Ebay if mine ever fails! A bit like the steel wheels. Last edited by lightning on 19th Mar 2025 1:19pm. Edited 1 time in total |
ruben Member Since: 04 Feb 2021 Location: ASTURIAS Posts: 362 ![]() ![]() |
No, you're not alone, I agree with that, I also think the 9" fits better with the environment and is less invasive, it looks better fitted and harmonious... the 11", and I'm not even mentioning the 13" ones, take on too much importance, everything else fades into the background and everything starts to look strange and too much like tuning and aftermarket style…all in a world where everything copies, at least until now, an unnameable American manufacturer with a copied name by the way... I only recognize a point of practicality in large screens because they actually look better... but for me it's not worth the effort, and I'm not convinced by the result, so I like my 9" as it is… And it's a shame, it would have been wonderful, and unique, if LR thought of a quick disconnection system and had made it portable... it would have been a total success!!! Defender 110 SE I6 D250 23MY
ExDiscovery 3 TDV6 SE |
Moo Member Since: 01 Oct 2021 Location: UK Posts: 1472 ![]() ![]() |
Agree. I think the original screen just looked right. Never once did I think I needed a bigger screen when using it. Reminds me of those Ali Express add ons. Eiger Grey MY23 D250 SE with bits. Known as Noddy.
Hairy Dan Member Since: 25 Apr 2013 Location: NW Durham Posts: 1448 ![]() ![]() ![]() |
Can anybody who has done the Alliexpress option tell me the difference between these two screens, both from the seller Wimafun?
Option 1 Option 2 Apart from the price ![]() -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
J77 Member Since: 04 Nov 2019 Location: Fife Posts: 3493 ![]() ![]() |
Yup, my 24MY 90 came with the larger screen and I really don’t see the point of it and it looks more aftermarket. 24MY 90 D250 HSE, Tasman Blue
The Chinese manufacture well when they manufacture for a well-known manufacturer foreign or native, but under quality control parameters, however, when it comes to equipment without a brand or control, the disparity in terms of solutions and quality is enormous. ...things that seem the same are not, but maybe they are... who knows... Or maybe you'll get lucky and an Alpine or Panasonic technician will do it with their components in his spare time and put it on the market! Who knows again? I try to avoid Aliexpress, I only do it for small storage accessories and things of little value... that can be thrown away without crying later... when we talk about a certain amount of money and especially about devices that have to be plugged into the Defender, I think about it a lot! So, IMHO don’t think about it too much, with things from AliExpress, there's probably no difference...or maybe there is...who knows...in the end it will last a couple of months...or maybe 4!! ![]() ExDiscovery 3 TDV6 SE |
@Hairy Dan I don’t believe there is a difference. @LostCause and I purchased the same display from the same vendor at different times and prices. To confirm you could contact the vendor directly. They normally answer within 1 business day. I’m going on my fourth month since installing it and have had no issues at all. Using the GAP tool I’ve successfully installed the MY 25 Pivi interface. The WILMAFUN product was packaged well, has an excellent mount which is much better than the factory brackets or those supplied by Simon @powerfulUK, although I’m indebted to Simon for his excellent installation videos as well as members such as @mmbanf and yourself for giving me the confidence to attempt and succeed my upgrade.
Regards, Bob |
Thanks Thunderbob for that, I have been looking at them and trying to work out what the difference was and like you I can't see one, I did message the seller but received a poorly translated message which didn't make much sense. But as I can't speak Chinese and the seller can't speak English it is perfectly acceptable and I can't criticise them for that.
I can well believe that it will be a quality item, I have bought lots of things from Alliexpress and the only item I have had a problem with was instantly refunded, I even have a 3d printer which must be getting on for 12 years old now which was purchased from Alliexpress and it still works perfectly. Cheers Ian -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
just to clarify, in case I have explained myself badly, I am not saying that what Alliexpress sells is necessarily bad in itself, I was only trying to say, based on your question, that it is generally difficult to know if two apparently identical products, but with different prices, are really the same or not, and I only say and I maintain, that this is difficult to know and many times it is quite an adventure to discover it, there is a lot of variability in that sense, sometimes they are, and their quality is the same, and other times however they are not at all, they do not have very clear standards...with high value products it is a risk, although you can always undo the deal and return it of course...
However, Thunderbob's experience and testimony have much more value than my own experience and opinion, it is clear that I have not bought a screen from Alliexpress and he has. Defender 110 SE I6 D250 23MY ExDiscovery 3 TDV6 SE |
Well thanks to ThunderBob and LostCause I now have a large screen fitted and working, screen arrived from China within a week and finally got around to fitting it today. I followed the Powerful UK video to remove the 10" screen, then using the brilliantly designed mount was able to fit the new bigger screen and get the car put back together in about 90 minutes. I opted to use my IID G4 tool to code the new screen instead of opting for the vendor to remote in and code it for me, mainly because I don't have a windows laptop.
![]() Screen looks great, is very responsive and I'm really happy with it ![]() ![]() Click image to enlarge ![]() Click image to enlarge Cheers Ian -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
One bonus thing that I've noticed with the Chinese screen is that the carplay displays 3 rows of icons now. I'm pretty sure the other day it was only showing as 2 rows when I first fitted it but when I got in today it now shows 3 rows so I can get nearly all icons on one page.
![]() ![]() Click image to enlarge Cheers Ian -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
