![]() | Home > Series Land Rovers > Half door seal |
MarkBrown Member Since: 03 Oct 2022 Location: Mid Wales Posts: 576 ![]() ![]() ![]() |
I can’t remember but I’d put some sealant around the door top bolts ( which I didn’t ) to stop them leaking from around the bolts ( which mine now do)
Stiff1 Member Since: 09 Dec 2014 Location: Cornwall Posts: 602 ![]() ![]() ![]() |
So like this?
Lip to outside and pointing down over edge of door ![]() Click image to enlarge ![]() Click image to enlarge |
Devon-Rover Member Since: 22 Jan 2015 Location: South Devon Posts: 926 ![]() ![]() ![]() |
I've always done it flat side down, and the lip on the outer edge.
FWIW ![]() |
Bowbearer Member Since: 12 Aug 2022 Location: Norfolk Posts: 229 ![]() ![]() ![]() |
No that’s the obvious way. It’s a Land Rover.
![]() I thought it was that way round. Recent trip to Dunsfold LR and looked at their series doors. Lip on inside facing down. This is because on the outside you have 2 drain holes for the window channel. If you have the lip on the outside it blocks them. |
Thanks for that, I'll give it go this weekend.
Careful not to overtighten the bolts
They are only held in with a sot weld. Found out the hard way! |
JamieL Member Since: 20 Sep 2015 Location: Chesterfield Posts: 30 ![]() ![]() |
Dunsfold have it wrong. Lip on inside facing up so any water that gets under it doesn't get in and gets channelled away
o4dn Member Since: 08 Jan 2010 Location: South West Posts: 591 ![]() ![]() ![]() |
I'll second that! ![]() -- 2009 2.4 Puma Defender 90 SW 1979 Land Rover Series 3 88" |
