Home > Series Land Rovers > Half door seal
Stiff1
Half door seal
So which way round... I know they go on the top, just offering up for perspective
Post #1030826 7th Apr 2024 12:47pm
MarkBrown
Wales 1983 Defender 110 Other HT Auto Keswick Green
I can’t remember but I’d put some sealant around the door top bolts ( which I didn’t ) to stop them leaking from around the bolts ( which mine now do)
Post #1030827 7th Apr 2024 12:51pm
Stiff1
So like this?
Lip to outside and pointing down over edge of door
Post #1030828 7th Apr 2024 12:57pm
Devon-Rover
I've always done it flat side down, and the lip on the outer edge.
FWIW Cool Also can be found on Fb, Ytube, Insta & Twitter @4WDSouthwest
Post #1030833 7th Apr 2024 1:25pm
Bowbearer
United Kingdom 1985 Defender 110 200 Tdi SW Auto Baltic Blue
No that’s the obvious way. It’s a Land Rover. Whistle
I thought it was that way round.
Recent trip to Dunsfold LR and looked at their series doors.
Lip on inside facing down.
This is because on the outside you have 2 drain holes for the window channel.
If you have the lip on the outside it blocks them.
Post #1033807 4th May 2024 3:01pm
Stiff1
Thanks for that, I'll give it go this weekend.
Post #1033835 5th May 2024 1:36am
Bowbearer
Careful not to overtighten the bolts
They are only held in with a sot weld.
Found out the hard way!
Post #1033847 5th May 2024 9:34am
JamieL
Dunsfold have it wrong. Lip on inside facing up so any water that gets under it doesn't get in and gets channelled away
Post #1062220 6th Mar 2025 8:55pm
o4dn
France 2009 Defender 90 Puma 2.4 SW Alaska White
I'll second that! Thumbs Up “A Land Rover immobilized is a moral defeat for the driver and bad publicity for the vehicle, […] it's up to you to do justice to your Land Rover!” - Land Rover Driving Technique.
2009 2.4 Puma Defender 90 SW
1979 Land Rover Series 3 88"
Post #1062291 7th Mar 2025 3:40pm
