Home > Expedition & Overland > Calling Alu-Cab Icarus owners
John P
United Kingdom 2012 Defender 90 Puma 2.2 SW Corris Grey
Can anybody that has a Icarus installed tell me if their interior light by the rear view mirror comes on with the press of the central locking when opening? Mine seems to be only on or off. It does not come on when I open the car via the central locking.
Thanks
John
Post #1061560 27th Feb 2025 10:51pm
sharkey964
France 2007 Defender 90 Puma 2.4 XS CSW Santorini Black
No,mine doesn't come on.
Marc
Post #1061568 28th Feb 2025 8:40am
John P
Thanks for confirming. Thumbs Up
Post #1061573 28th Feb 2025 9:32am
Hendrix
England 2013 Defender 110 Puma 2.2 USW Santorini Black
Yep mine only work with switches in the lights. Andy
1996 300TDI 110 SW
2013 TDCI 110 Utility
Post #1061574 28th Feb 2025 9:38am
Bill1919
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Corris Grey
The original front interior light is operated by a two-way switch which switches the return (-ve). Off, straight to earth, or earth via the alarm module. On my Icarus the 3 leads for the interior light can be found at the back of the map shelf on the RHS, the two ‘earth’ leads and a permanent 12v supply. The Alu-cab light has only a one-way switch, so you need to choose between having the light operated by the opening the door or switching it on and off when required. 1988 110 csw 2.5Td (19J) (gone)
1992 110 csw Tdi200 (gone)
1995 110 csw Tdi300 (gone)
2015 110 XS csw 2.2 puma
Post #1061577 28th Feb 2025 10:29am
John P
Yeah, I spotted this. It's just disappointing that for the cost, you would have thought they would have put in an appropriate light switch to follow the standard switching.
Post #1061579 28th Feb 2025 10:33am
db950
United Kingdom 1997 Defender 110 300 Tdi HT Nato Green
I wired mine so you leave the Icarus light switch to ‘on’ then it is switched on and off by the door pin switches and also a switch on the dash if you want it on whilst both doors are closed. 1997 Ex-MOD 110, Pop Top Camper, build thread https://www.defender2.net/forum/topic72352.html
2014 Discovery 4 SE Tech
Instagram @the110camper
Post #1061806 3rd Mar 2025 11:37am
Bill1919
I was going the wire mine the same way as db950, I even brought a 2-way switch to mount on the dash, but the earth return via the alarm module does not go fully open circuit. This results in the light remaining on with the doors closed, albeit just a dim glow. Not sure if this is a faulty alarm module or something else. One day I'll find the time investigate further. 1988 110 csw 2.5Td (19J) (gone)
Post #1061809 3rd Mar 2025 12:36pm
db950
Don’t think it’s due to a faulty alarm module, my light will every now and again flicker on for a millisecond and I don’t have an alarm module!
I think it’s due to it having a positive supply to it permanently and picking up a very faint earth, yours via the module, mine via the relay used for earth switching from the dash switch.
To eliminate would probably have to switch both the positive and earth via relays from the door switches Thumbs Up 1997 Ex-MOD 110, Pop Top Camper, build thread https://www.defender2.net/forum/topic72352.html
Post #1061822 3rd Mar 2025 1:52pm
