Home > General & Technical (L663) > 400e Charging HV Battery from Engine
Page 2 of 3 <123>
Tuath
If you read my posts fully as to what we did you will see that isn't the case - Battery Hold, then Hybrid, then Electric, then refuel with petrol (at 3rd station in our case, first actually to have fuel), recharge battery from engine once full (to regain the reserve), then top up at next petrol station with fuel so battery and tank are both full again - it's all there above if you look...
As I say - depends on use case, scenario and where you are using these vehicles I guess - not everyone will come up against these situations or be prepared / pre-think.
Post #1060461 13th Feb 2025 10:39am
TexasRover
Basically a very expensive Jerry Can.
I have a P38 with LPG, one benefit is that you have a decent reserve in the petrol tank. It works and makes sense.
Good to see this option exists in the p400e for those people that want to use it.
Post #1060462 13th Feb 2025 10:53am
Tuath
Yep exactly Very Happy (very expensive is right, but glad the car I was in had the option none-the-less).
My Td5 has a jerry can in the back for the exact same reason, but as I think I also mentioned the recharge from engine feature means I don't lose the space a jerry takes up, the octane level doesn't drop in the caned fuel over time, and my wife is much happier not having a tin of fuel in the back Very Happy
As you say - great it has the feature for those that have a use, especially as it seems most PHEV vehicles don't (and we just got lucky with the car we had in the past!)
Post #1060466 13th Feb 2025 11:13am
pjm-84
Why not just save the battery after charging from the mains if you want a electric Jerry can?
No massive reduction in mpg when replacing the depleted battery charge. i.e you will use more petrol range then electric range you get back.
Post #1060468 13th Feb 2025 11:28am
Tuath
Please, please read my post if you are going to reply - that is what I do / did - but could not recharge in the middle of nowhere with deep snow and ice to have onward reserve after using it! It is not a common use case (I understand that) but there is good reason in some circumstances for the feature.
Post #1060470 13th Feb 2025 11:46am
Hunter
Austria
Loading whilst driving
You might want to have a look at this German solution, build for portable batteries but can probably also modified for PHEV.
https://de.ecoflow.com/products/800w-alternator-charger
Post #1060614 15th Feb 2025 9:56am
Tuath
An interesting option. I'm guessing warranty would go out the window if it were hard wired into the HV system (and it seems that the L663 400e can charge from the engine natively from what's been posted), but if we decided against the L663 for other reasons then this potentially opens options for cars that would otherwise be off our list - thank you for the idea Smile
Post #1060647 15th Feb 2025 5:32pm
stevemfr
France
pjm-84 wrote:
Had it on an Outlander and pointless to be honest. Consumption would drop to low 20s from mid to high 30s. That had a save button and a charge button.
The BMW doesn't do this, but will put charge back in under braking etc. The most you can build up from a flat battery is 2miles. That said it will do mid to high 30s (mpg) from the 3.0l petrol engine. The Save button in the BMW does just that.
Especially in this day and age of extremely partisan politics, I find myself having less and less tolerance for people who a.) don't read, and b.) cannot see beyond the boundaries of their little bubble and think they have the world figured out for everyone based on their own little life experiences. Sorry if that comes across as harsh - maybe I am just becoming more grumpy as I get older.
We have been approached by several parties to modify the PHEV. And all have use cases where charging the PHEV battery through the motor makes a lot of sense.
In the grand scheme of things EV, 800w is like a BIC lighter compared to an industrial furnace. It's just not going to do very much for you.
I don't think this solution has much to do with Germany other than the webshop; Ecoflow is a very Chinese company. Wink
Metisse wrote:
Too many replies from those who assume and do not have an L663 p400e!!
Thumbs Up
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s,
2 FL1s and a L663 on the way
Post #1060756 17th Feb 2025 10:14am
pjm-84
Not harsh at all.....my bubble is however quite large.
Post #1060758 17th Feb 2025 10:59am
Tuath
I think I need to be less polite maybe Laughing I will admit to getting frustrated too. I also I agree the wattages involved don't stack up (Twisted have an EV conversion for the Td5 and the APU charger they are developing is currently towed on a trailer at present so that gives an idea of practical scale). As an integrated part of the vehicle from manufacture that is aware at the software level I'm guessing there are economies of scale to be gained (otherwise the Cayenne and i8 would need tow bars Smile ).
I've been researching and reading further on this, and specifically the L663 400e. I'm still to find anything in writing that is completely clear or conclusive, but I think I've an idea of how it works with this specific vehicle.
Unlike the Cayenne and Touareg (with specific e-charge modes), and the i8 (with active charging in sport mode) I do not believe the L663 400e actively charges from the engine (ie. there is no specific component or uprated alternator that directly charges the HV battery from the combustion engine). What it appears to do in 'Save' mode is fully run the vehicle on the combustion engine and set the regenerative hardware (breaks, etc.) to max. This causes 'drag' for want of a better term, and without any electric assistance the engine load is very high and hence the MPG plummets.
I need to confirm my understanding is correct, and then think carefully through scenarios to decide if this 'regenerative plus’ mode is sufficient for our particular needs. It certainly seems effective, and can charge the battery quite quickly for how it's working. However, unlike the Cayenne for example, I do not believe it would add charge whilst parked - that is not important per-say, but illustrates the difference that I believe exists between the approaches taken by BMW / VAG and JLR.
Post #1060759 17th Feb 2025 11:17am
o-ren-ishii
Netherlands
@Tuath: Well, you are mistaken there. The P400e uses the zf 8p75ph gearbox, which has integrated generator.
I can assure you, like I stated earlier above, the P400e does charge the HV battery. But, it stops after a few percent. Source: I have got the car. Wink
And yes, I agree with you some people here reply to almost anything - even if they assume a lot. That can be quite annoying when trying to find correct help.
Post #1060760 17th Feb 2025 12:25pm
Tuath
Thank you once again o-ren-ishii – I’m a real appreciator of detail / information like that! Very Happy I never thought to look at components, but that confirms things nicely.
Looking closer at the 8p75ph transmission it includes a compact 134hp / 99kW motor that indeed can act as a generator. The Jeep Wrangler 4Xe (that Jeep decided not to produce for RHD markets) uses the same gearbox, and that vehicle has both ‘Save’ and a dedicated ‘Recharge’ modes that look to use this integrated motor as the power source.
It may even be that the charging rate, level at which charging ceases, and general charging behaviour could be coded – as based on what you have confirmed it’s all effectively just software as the hardware is there. However, knowing for certain that it can actively charge from the engine is sufficient for us I think.
I find forums invaluable, but they are just the same as the rest of the Internet – validate your sources, apply common sense, keep a healthy scepticism, and try not to get too frustrated!! Wink For ever right piece of information online there’s…
Post #1060839 18th Feb 2025 11:23am
nobbyclark
United Kingdom 2005 Defender 110 Td5 CSW Tonga Green
I have a P400e Defender. On a long motorway or A-road run, I put it into EV Save mode and it will recharge 1 mile per 5-6 miles travelled. I recently drove to Edinburgh and recharged 20 miles between home and the city centre (120 miles). I don't think it will get the maximum though. I drove to London last year and managed 21 recharged miles over 325 miles travelled. 2024 Defender 110 X-Dynamic HSE P400
Post #1060866 18th Feb 2025 5:16pm
Metisse
As stated before, and confirmed by nobbyclark above, the p400e definitely does recharge the hybrid battery directly from the engine when in 'Save' mode. It is not just more regeneration from the brakes, the electric motor swaps to being a generator and charges the battery. Like nobbyclark I have recharged to 20+ miles range but as with all EV's the last 20-25% takes a great deal longer to recharge which is probably why we only got to 20 odd miles of EV use. Many people with pure EV's only go between 20-80% charge as it is much quicker and is said to prolong battery efficiency.
The Defender is different to some other Land Rover PHEV Hybrid's in that the motor/generator is in the gearbox as shown by o-ren-ishii. This allows the Defender to be in 4WD in full EV mode and it can happily go off-road in full EV. Some off-road selections will force the engine to run (wading is one) but it is very good, see this
The Discovery Sport has two distinct motors. The petrol engine drives the front axle and the electric motor drives the rear axle. When you run out of electric power the vehicle reverts to 2WD and which is why I did not get one.
When the p400e first came out I watched a lot of this guy's videos
He is a french pilot and english is not his first language so explanations can be slower and more expansive as he searches for the right language to use to describe his in-depth knowledge. It was watching these videos when there was little other info available that convinced me to get a p400e when I could afford it!
The only issue I had was the vehicle refused to start in EV mode and regularly reverted to the engine with 'EV temporarily unavailable' showing on the screen. Like others on this forum found it turned out to be the High Voltage Heater that had a fault. It was thankfully still in warranty and replaced. The vehicle is now exactly as I had hoped and EV is available from the start. It will also start in 'EV' mode if I had it selected when I last stopped rather than reverting to 'Hybrid' unless the hybrid battery has been exhausted.
Have fun, it's a great car/toy Very Happy Very Happy 2022 Defender 110 HSE P400e Tasman Blue
Post #1061068 21st Feb 2025 9:10pm
pjm-84
The ZF box in the BMW also charges when SAVE is pressed and BCM is set over the level required. Its quite efficient (assuming the same ZF box is utilized in both vehicles) and provided 13miles of range over 30miles on the motorway at 65mph.
With a combination of a downgrade, braking and corners on a A road in rural Wales - 9miles gave 8miles of EV range. (About 2.3miles / kW in the BMW)
Post #1061984 4th Mar 2025 3:55pm
Page 2 of 3 <123>
