![]() | Home > General & Technical (L663) > 400e Charging HV Battery from Engine |
| TexasRover Member Since: 24 Nov 2022 Location: Paris Posts: 1298
Basically a very expensive Jerry Can.
I have a P38 with LPG, one benefit is that you have a decent reserve in the petrol tank. It works and makes sense. Good to see this option exists in the p400e for those people that want to use it. |
| Tuath Member Since: 12 Feb 2025 Location: UK Posts: 13
Yep exactly
My Td5 has a jerry can in the back for the exact same reason, but as I think I also mentioned the recharge from engine feature means I don't lose the space a jerry takes up, the octane level doesn't drop in the caned fuel over time, and my wife is much happier not having a tin of fuel in the back As you say - great it has the feature for those that have a use, especially as it seems most PHEV vehicles don't (and we just got lucky with the car we had in the past!) |
| pjm-84 Member Since: 12 Apr 2021 Location: Hampshire Posts: 714
Why not just save the battery after charging from the mains if you want a electric Jerry can?
No massive reduction in mpg when replacing the depleted battery charge. i.e you will use more petrol range then electric range you get back. |
Please, please read my post if you are going to reply - that is what I do / did - but could not recharge in the middle of nowhere with deep snow and ice to have onward reserve after using it! It is not a common use case (I understand that) but there is good reason in some circumstances for the feature.
| Hunter Member Since: 29 Nov 2020 Location: Vienna Posts: 1
You might want to have a look at this German solution, build for portable batteries but can probably also modified for PHEV.
https://de.ecoflow.com/products/800w-alternator-charger |
An interesting option. I'm guessing warranty would go out the window if it were hard wired into the HV system (and it seems that the L663 400e can charge from the engine natively from what's been posted), but if we decided against the L663 for other reasons then this potentially opens options for cars that would otherwise be off our list - thank you for the idea
| stevemfr Member Since: 18 Sep 2022 Location: Strasbpurg Posts: 159
Especially in this day and age of extremely partisan politics, I find myself having less and less tolerance for people who a.) don't read, and b.) cannot see beyond the boundaries of their little bubble and think they have the world figured out for everyone based on their own little life experiences. Sorry if that comes across as harsh - maybe I am just becoming more grumpy as I get older. We have been approached by several parties to modify the PHEV. And all have use cases where charging the PHEV battery through the motor makes a lot of sense.
In the grand scheme of things EV, 800w is like a BIC lighter compared to an industrial furnace. It's just not going to do very much for you.
I don't think this solution has much to do with Germany other than the webshop; Ecoflow is a very Chinese company.
RRC 2Dr, RRC 4Dr, P38, and 2 L322s, 2 FL1s and a L663 on the way |
Not harsh at all.....my bubble is however quite large.
I think I need to be less polite maybe
I've been researching and reading further on this, and specifically the L663 400e. I'm still to find anything in writing that is completely clear or conclusive, but I think I've an idea of how it works with this specific vehicle. Unlike the Cayenne and Touareg (with specific e-charge modes), and the i8 (with active charging in sport mode) I do not believe the L663 400e actively charges from the engine (ie. there is no specific component or uprated alternator that directly charges the HV battery from the combustion engine). What it appears to do in 'Save' mode is fully run the vehicle on the combustion engine and set the regenerative hardware (breaks, etc.) to max. This causes 'drag' for want of a better term, and without any electric assistance the engine load is very high and hence the MPG plummets. I need to confirm my understanding is correct, and then think carefully through scenarios to decide if this 'regenerative plus’ mode is sufficient for our particular needs. It certainly seems effective, and can charge the battery quite quickly for how it's working. However, unlike the Cayenne for example, I do not believe it would add charge whilst parked - that is not important per-say, but illustrates the difference that I believe exists between the approaches taken by BMW / VAG and JLR. |
| o-ren-ishii Member Since: 25 Jul 2023 Location: The Hague Posts: 43
@Tuath: Well, you are mistaken there. The P400e uses the zf 8p75ph gearbox, which has integrated generator.
I can assure you, like I stated earlier above, the P400e does charge the HV battery. But, it stops after a few percent. Source: I have got the car. And yes, I agree with you some people here reply to almost anything - even if they assume a lot. That can be quite annoying when trying to find correct help. |
Thank you once again o-ren-ishii – I’m a real appreciator of detail / information like that!
Looking closer at the 8p75ph transmission it includes a compact 134hp / 99kW motor that indeed can act as a generator. The Jeep Wrangler 4Xe (that Jeep decided not to produce for RHD markets) uses the same gearbox, and that vehicle has both ‘Save’ and a dedicated ‘Recharge’ modes that look to use this integrated motor as the power source. It may even be that the charging rate, level at which charging ceases, and general charging behaviour could be coded – as based on what you have confirmed it’s all effectively just software as the hardware is there. However, knowing for certain that it can actively charge from the engine is sufficient for us I think. I find forums invaluable, but they are just the same as the rest of the Internet – validate your sources, apply common sense, keep a healthy scepticism, and try not to get too frustrated!! |
| nobbyclark Member Since: 19 Jan 2011 Location: Cumbria Posts: 56
I have a P400e Defender. On a long motorway or A-road run, I put it into EV Save mode and it will recharge 1 mile per 5-6 miles travelled. I recently drove to Edinburgh and recharged 20 miles between home and the city centre (120 miles). I don't think it will get the maximum though. I drove to London last year and managed 21 recharged miles over 325 miles travelled. 2024 Defender 110 X-Dynamic HSE P400
| Metisse Member Since: 03 Jun 2022 Location: Wiltshire Posts: 11
As stated before, and confirmed by nobbyclark above, the p400e definitely does recharge the hybrid battery directly from the engine when in 'Save' mode. It is not just more regeneration from the brakes, the electric motor swaps to being a generator and charges the battery. Like nobbyclark I have recharged to 20+ miles range but as with all EV's the last 20-25% takes a great deal longer to recharge which is probably why we only got to 20 odd miles of EV use. Many people with pure EV's only go between 20-80% charge as it is much quicker and is said to prolong battery efficiency.
The Defender is different to some other Land Rover PHEV Hybrid's in that the motor/generator is in the gearbox as shown by o-ren-ishii. This allows the Defender to be in 4WD in full EV mode and it can happily go off-road in full EV. Some off-road selections will force the engine to run (wading is one) but it is very good, see this The Discovery Sport has two distinct motors. The petrol engine drives the front axle and the electric motor drives the rear axle. When you run out of electric power the vehicle reverts to 2WD and which is why I did not get one. When the p400e first came out I watched a lot of this guy's videos He is a french pilot and english is not his first language so explanations can be slower and more expansive as he searches for the right language to use to describe his in-depth knowledge. It was watching these videos when there was little other info available that convinced me to get a p400e when I could afford it! The only issue I had was the vehicle refused to start in EV mode and regularly reverted to the engine with 'EV temporarily unavailable' showing on the screen. Like others on this forum found it turned out to be the High Voltage Heater that had a fault. It was thankfully still in warranty and replaced. The vehicle is now exactly as I had hoped and EV is available from the start. It will also start in 'EV' mode if I had it selected when I last stopped rather than reverting to 'Hybrid' unless the hybrid battery has been exhausted. Have fun, it's a great car/toy |
The ZF box in the BMW also charges when SAVE is pressed and BCM is set over the level required. Its quite efficient (assuming the same ZF box is utilized in both vehicles) and provided 13miles of range over 30miles on the motorway at 65mph.
With a combination of a downgrade, braking and corners on a A road in rural Wales - 9miles gave 8miles of EV range. (About 2.3miles / kW in the BMW) |
